use GUI to create low pass filter
awanis
Junior Member level 1
malaysia
hai...
im the beginers in study of matlab...
can i know how can i use GUI to create the low pass filter..
with butterworth type and using bilinear method...
pleasse....
im stuck with this...
:cry:
hey,
try simply design functions, i would suggest, for example freqz or fvtool, try the help function, you have to get used to it. help butter, than you only have to use your specifications. there are examples!!
first butter, than you can watch it with freqz!
awanis said:
hai...
pleasse....
:cry:
Don't cry. At least not just now
The GUI is called FDAtool. To learn about is use Matlab help
by the way, unless you ask proper questions, very few people will answer you
thanks a lot..
a will try to solve..
by the way if can't get the solution...
i will ask again ya...
haiiiiiiiiiiiii
can i know about filter implementation on fpga and pls give verilog code of that and how to transfer image to fpga (altera nios 2) and pls give code also.
