Use generic in package: VHDL
jeetesh
I have defined a generic in entity and I want to pass it to package. How to do this, without using component and others. I read somewhere that VHDL-2008 provides this feature. But I don't know how to use it? This is what I am trying to do (just an example):
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
library ieee;
use ieee.std_logic_1164.all;
package pack is
   generic(N: integer := 15);
   port ( in1, in2: std_logic_vector(N downto 0));
   function and15(in1, in2: std_logic_vector) return std_logic_vector;
end pack;
package body is
    function and15(in1, in2: std_logic_vector) return std_logic_vector is
    variable result: std_logic_vector(N downto 0);
    begin
         result := in1 and in2;
    end pack;
library ieee;
use ieee.std_logic_all;
use work.pack.all;
entity andgate is
   port (in1, in2: std_logic_vector(N downto 0);
              out1: std_logic_vector(N downto 0));
end andgate;
architecture arch of andgate is
begin
      out1 <= and15(in1, in2);
end arch;
You are making simply things complicated. No VHDL2008 needed, just write
package pack is
end pack;
package body pack is
  variable result: std_logic_vector(in1'left downto 0);
  begin
  return result;
-- or simply return in1 and in2;
end pack;
package pack is
end pack;
  begin
  return result;
end pack;
Thank you FvM for your reply. We can design this like you did, but can we pass generic value to a package. If yes, then how? Considering this example.
As said, generic isn't needed in the present case. A function parameter connected to a constant should work in the general case. At least it did for me up to now.
When you write a package with a generic - you cannot use the package directly until you have created an instance of it.
8
package pack_inst is new work.pack
    generic map(
        N => 100
--and then in code:
use work.pack_inst.all;
I assume you're only going to use this in simulation - no synthesis tools (at least Quartus, ISE and Vivado) support generics on packages (even though they claim vhdl 2008 support).
But I agree with FvM - in your example a generic is not needed - dont overcomplicate code.
Thank you FvM and TrickyDicky. I know generic is not needed in my example, but I want to use this in some other designs. That was just an example, not design.
TrickyDicky, I got it. Thanks for suggesting the instance of the package. I am using synplify and will check wether its gonna work there or not..
