usb to rs232 cable problem
tuanhung09
Newbie level 3
Dear all,
I have a USB to RS232 cable
(You can see it here)
When I installed driver for it in my desktop, it was recognized. However, when I installed driver for it in my laptop, the error message was "usb device not recognized"". When checking at device manager, there was no Ports item (my laptop has not COM and LPT port). Under the Universal Serial Bus Controllers, there was an item, which was named "unknown device". I think in this case, the driver was not installed. Could anyone help me.
Thank you very much!
MagixD
Junior Member level 1
usb to rs232 driver not recognized
What OS are you runnning on your machines (my crystal ball isn't working today...)? Have you tried to install the driver manually?
The converter chip used on this converter is a PL2303, as you can see in the link you have posted.
magixD
tuanhung09
Newbie level 3
I am using Windows XP SP2 in both of laptop and desktop. I installed many times, including manual installation.
MagixD
Have you already tried to reinstall the drivers for your USB host controller(s)?
Maybe you should deactive and deinstall all drivers for the cable and the host controller(s) and than reinstall them once again. I had cases where this fix helped.
magixD
