I have a USB camera that has been made for research purpose. I am going to connect this camera to the computer via Ethernet with minimum effort and cost. I am thinking of an ethernet to USB converter. (USB female to RJ45)
I have found some kinda router or server(?) that makes it possible but I need a simple kit or electronic board that I can connect my camera at one end and it connects to the PC via Ethernet at the other end.
*. you need usb host to talk to usb device, SL811HS for example or use OTG device like Atmel AT90USB1287.
*. create stack for the camera, if there's any linux driver for your camera, please learn from the code
*. add ethernet module or chips like ENC28J60 to your microcontroller (TUXgraphic project for example).
*. then started bridging your usb to ethernet..
