* \file
* \brief Main functions for Keyboard example
* Copyright (c) 2009-2011 Atmel Corporation. All rights reserved.
* \asf_license_start
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice, this
* list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. The name of Atmel may not be used to endorse or promote products derived
* from this software without specific prior written permission.
* 4. This software may only be redistributed and used in connection with an Atmel
* AVR product.
* THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
* EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* \asf_license_stop
#include "compiler.h"
#include "preprocessor.h"
#include "board.h"
#include "gpio.h"
#include "sysclk.h"
#include "sleepmgr.h"
#include "conf_usb.h"
#include "udc.h"
#include "udd.h"
#include "ui.h"
//volatile static bool main_b_kbd_enable = false;
volatile static bool main_b_kbd_enable = true;
/*! \brief Main function. Execution starts here.
int main(void)
irq_initialize_vectors();
cpu_irq_enable();
// Initialize the sleep manager
sleepmgr_init();
sysclk_init();
board_init();
ui_init();
ui_powerdown();
ui_wakeup_enable();
volatile uint32_t freq = sysclk_get_cpu_hz();
freq ++;
LED_Toggle(LED3);
// Start USB stack to authorize VBus monitoring
udc_start();
//udc_attach();
if (!udc_include_vbus_monitoring()) {
// VBUS monitoring is not available on this product
// thereby VBUS has to be considered as present
main_vbus_action(true);
// The main loop manages only the power mode
// because the USB management is done by interrupt
while (true) {
#ifdef USB_DEVICE_LOW_SPEED
// No USB "Keep a live" interrupt available in low speed
// to scan keyboard interface then use main loop
if (main_b_kbd_enable) {
static uint16_t virtual_sof_sub = 0;
if (700 == virtual_sof_sub++) {
static uint16_t virtual_sof = 0;
ui_process(virtual_sof++);
#else
sleepmgr_enter_sleep();
#endif
void main_vbus_action(bool b_high)
//if (b_high) {
// Attach USB Device
udc_attach();
//} else {
// VBUS not present
//udc_detach();
void main_suspend_action(void)
ui_powerdown();
void main_resume_action(void)
ui_wakeup();
void main_sof_action(void)
if (!main_b_kbd_enable)
return;
ui_process(udd_get_frame_number());
void main_remotewakeup_enable(void)
ui_wakeup_enable();
void main_remotewakeup_disable(void)
ui_wakeup_disable();
bool main_kbd_enable(void)
return true;
void main_kbd_disable(void)
* \mainpage ASF USB Device HID Keyboard
* \section intro Introduction
* This example shows how to implement a USB Device HID Keyboard
* on Atmel MCU with USB module.
* The application note AVR4903 provides information about this implementation.
* \section startup Startup
* The example uses the buttons or sensors available on the board
* to simulate a standard keyboard.
* After loading firmware, connect the board (EVKxx,XPlain,...) to the USB Host.
* When connected to a USB host system this application provides a keyboard application
* in the Unix/Mac/Windows operating systems.
* This example uses the native HID driver for these operating systems.
* \copydoc UI
* \section example About example
* The example uses the following module groups:
* - Basic modules:
* Startup, board, clock, interrupt, power management
* - USB Device stack and HID modules:
* <br>services/usb/
* <br>services/usb/udc/
* <br>services/usb/class/hid/
* <br>services/usb/class/hid/keyboard/
* - Specific implementation:
* - main.c,
* <br>initializes clock
* <br>initializes interrupt
* <br>manages UI
* - specific implementation for each target "./examples/product_board/":
* - conf_foo.h configuration of each module
* - ui.c implement of user's interface (buttons, leds)
