The Pen Drive's Table of Contents has been corrupted.
So, go to the Tools in the Pen drive's property and select Check Now (Known as Scandisk in DOS and old Windows). Then, select all the check boxes and click start. This will take some time, may be 5 to 10 minutes depending upon the speed of your pen drive. And, you will have a .CHK file may in a folder named Found.000 Rename it to the file you lost it.
Don't forget to Click HELPED ME Button if this works....!
