help plz.. from the site below that i have read. Is this USBWIZ with Philips LPC2141 microcontroller can be interface to the LED display for a message display? **broken link removed**
im planning to design a message display board with a message or file from the USB flash disk...
is it difficult to send a file or message from the USB flash drive going to the microcontroller then it will be display to the LED board display??
do you want a LED display or an LCD message display.
Anyways yes you can interface it, though you might have to modify a couple of output connections LED interface to 8051. The connections should be similar.
In supposition you want and LCD display which consumes much less power. e.g. HD44780 is a typical LCD.
**broken link removed** should get you started on building an LCD with a microcontroller.
How to program this USBWIZ with Philips LPC2141 microcontroller so that it can log or get a message or file from the USB flash disk going to the microcontroller?
