behranghm
Member level 1
I am using a bootloade sample code which turns at90USB1286 into a DFU class bootloader which works perfectly well with Atmel’s FLIP application under AVRstudio. Now my problem is that it only works just once and the apparent reason is that as I program the device with a USB flash application via the DFU bootloader, the DFU driver is uninstalled from the PC and is replaced by the application driver. I think just like the UART bootloader which should be supported by the main application, I should be using a USB application with dual configuration, one for the application itself and another one for the DFU bootlaoder. Now you guys, any hints? About such an application ? How about the drivers for such an application?
