JSmith1980
Newbie level 2
Hi all
Im new to these forums and I am planning on building a USB device that will sit between a PC and an audiophile DAC.
High end audio is an interest of mine and I want the convenience of streaming audio from a PC via the USB line, but I also wanted to make sure that the differential data from the USB line going into the DAC is "clean".
The plan is to .......
1) Leave the power and ground coming from the PC along the USB line disconnected as it enters the device.
2) Use a LTC490 differential amplifier as a repeater for the data line coming in which will be powered by a battery.
3) The data would then enter a digital buffer/PLL to line up the data and prevent any possible error/jitter (something overkill) also powered by a battery.
4) A voltage limiter that would keep the maximum output voltage to the necessary level.
I am not sure what IC to use for stage 3 and I am not sure how to limit DC. Im not a design engineer but I have a background in electronics. If anyone could possibly suggest a solution, it would be very much appreciated.
Thanks
JSmith
Thanks
JSmith
