NVergunst
Member level 1
I am looking for a way to implement HS USB 2.0 (480mbps) on an FPGA. I have looked at the OpenCores solution but am slightly confused. The SVN has been updated within the past year, but the "status" has not changed in forever.
I am just wondering if anybody has any experience with this core and if it functions somewhat ok?
I want to build some test hardare using an FPGA and a UTMI PHY chip and just get 512byte bulk transfers going. I currently use microprocessors using full speed at 12mbps transfering 64byte blocks but USB is my bottleneck at these speeds. I want to make the leap, but with somewhat of a cushion there if need be! Also the reason for not going with the Cypress parts is just cost. At $15/each, and then $8+/each in high quantities it is just not economically feasible.
