Urgent !! pls Help ... insertion loss of RG# rated cables ?
gsmman
Junior Member level 2
india
Hi Friends
Please help me to find anRF cable with less than 1dB attenuation @ 900MHz
What will be the insertion loss of RG# rated cables ?/ plss help
Thanks in advance
Roy
Re: Urgent !! pls Help ...
You are in luck. You can use pretty much any cable you wish, just make it very short.
hello...how long should the cable be?
its only for few inches... hmnn 20 inches
Actly its for connecting an antenna with the gsm module ;
Can i use RG 178 ??
RegaRDS
roy
Added after 5 minutes:
RF cables for :
Insertion loss < 1dB at GSM 900MHz
Re: Coaxial Cable loss vs type and frequency
Coaxial Cable loss vs type and frequency:
Thank you :)
Roy
From that table, you can see there are a number of choices. For a 12" cable, the cable loss will be low, BUT do add in around .2 to .3 dB of loss for each connector you are added on each end when chosing the cable.
    gsmman
