LF_LF
Member level 1
Hi, i am a beginner in designing using VHDL. I need to construct interconnection between ADC(ADS7861 from Texas) and FPGA DE2 board. I have been told to use a SPI --- a serial to parallel SPi interface between ADC and FPGA. I have constructed the VHDL code for master(FPGA) and slave (ADC).
I understand that SPI only consists of 4 wires but my ADC having more than that. Therefore, i used Data_out( for MISO in slave), modeselect_A0 or convst (for MOSI in slave).
The total cycle needed for conversion is 32cycles but i only obtain the data till 16 cycles as the A0(I use mode 2 which is( M0=0,M1=1,A0=1)==>CHA1). After 16 cycle the A0 =0 so it convert for CHA0,so i stop then.
I put the CS always to low so that it is always ready to sent data.
For the code, i found out some errors in master and slave(i think is the same error for both) and i failed to fix it after many trial.
I hope that someone please help me in this case. Thank you in advanced
