URGENT HELP NEEDED: please check my source code (assembly)
-joe-
Newbie level 3
PLease help me with my source code...
there are several errors...
i am doing a 8x8 LED dot matrix display using ATMEL 89c51 chip and in assembly language
; I/O ADDRESS
NextButton EQU P1.0 ; PORT 1.0
BackButton EQU P1.1 ; port 1.1
AutoButton EQU P1.2 ; PORT 1.2
; VARIABLE ADDRESS
NUMBER EQU 625
ORG 0000H
MAIN: MOV R1, #01H
MOV R2, #0
MOV R3, #0
MOV DPTR, #TABLE
Button_Loop: MOV A, P1
JNB ACC.0, NextButton
JNB ACC.1, BackButton
JNB ACC.2, AutoButton
JB AutoBut, AutoButton
MOV B, #10h
DJNZ B, $
SJMP Button_Loop
NextButton: CLR AutoBut MOV A, ROW
INC A
LJMP Button_Loop
BackButton: CLR AutoBut
MOV A, ROW
DEC A
LJMP Button_Loop
AutoButton: SETB AutoBut
MOV A, ROW
SJMP Button_Loop
ROW: MOV A, R3
MOVC A, @A+DPTR
MOV R2, A
MOV P0, R2
MOV P2, R1
ACALL DELAY
MOV A, R1
RL A
MOV R1, A
INC R3
CJNE R1, #01H, ROW
MOV R3, #0
SJMP ROW
TOGGLE: MOV R2, #20
CPL P1.2 DJNZ R2, Toggle
DELAY: MOV TMOD, #01H
MOV TH0, #HIGH(-100000) MOV TL0, #LOW(-100000)
SETB TR0
JNB TF0, $
CLR TF0
RET
TABLE: DB 0F1H, 0EEH, 0E6H, 0EAH, 0ECH, 0EEH, 0F1H, 0FFH ;0
DB 0E0H, 0FBH, 0FBH, 0FBH, 0FBH, 0E3H, 0F3H, 0FFH ;1
DB 0E0H, 0F7H, 0FBH, 0FDH, 0EEH, 0F6H, 0F9H, 0FFH ;2
DB 0F1H, 0EEH, 0FEH, 0F9H, 0FEH, 0EEH, 0F1H, 0FFH ;3
DB 0FBH, 0FBH, OC1H, 0DBH, 0EBH, 0F3H, 0FBH, 0FFH ;4
DB 0E3H, 0DDH, 0FDH, 0C3H, 0DFH, 0DFH, 0C1H, 0FFH ;5
DB 0E3H, 0DDH, 0DDH, 0C3H, 0DFH, 0DFH, 0E1H, 0FFH ;6
DB 0F7H, 0F7H, 0F7H, 0FBH, 0FDH, 0FDH, 0C1H, 0FFH ;7
DB 0E3H, 0DDH, 0DDH, 0E3H, 0DDH, 0DDH, 0E3H, 0FFH ;8
DB 0E3H, 0FDH, 0FDH, 0E3H, 0DDH, 0DDH, 0E3H, 0FFH ;9
DB 0DDH, 0DDH, 0DDH, 0C1H, 0DDH, 0DDH, 0BAH, 0FFH ;A
DB 0C3H, 0DDH, 0DDH, 0C3H, 0DBH, 0DBH, 0C7H, 0FFH ;B
DB 0E3H, 0DDH, 0DFH, 0DFH, 0DFH, 0DDH, 0E3H, 0FFH ;C
DB 0C3H, 0DDH, 0DDH, 0DDH, 0DDH, 0DDH, 0C3H, 0FFH ;D
DB 0C1H, 0DFH, 0DFH, 0C3H, 0DFH, 0DFH, 0C1H, 0FFH ;E
DB 0DFH, 0DFH, 0DFH, 0C3H, 0DFH, 0DFH, 0C1H, 0FFH ;F
DB 0E3H, 0DDH, 0DDH, 0D9H, 0DFH, 0DDH, 0E3H, 0FFH ;G
DB 0DDH, 0DDH, 0DDH, 0C1H, 0DDH, 0DDH, 0DDH, 0FFH ;H
DB 0C1H, 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0C1H, 0FFH ;I
DB 0E7H, 0D7H, 0D7H, 0F7H, 0F7H, OF7H, 0C1H, 0FFH ;J
DB 0DDH, 0DBH, 0D7H, 0CFH, 0D7H, 0DBH, 0DDH, 0FFH ;K
DB 0C1H, 0DFH, 0DFH, 0DFH, 0DFH, 0DFH, 0DFH, 0FFH ;L
DB 0DDH, 0DDH, 0DDH, 0DDH, 0D5H, 0C9H, 0DDH, OFFH ;M
DB 0DDH, 0D9H, 0D9H, 0D5H, 0D5H, 0CDH, 0DDH, 0FFH ;n DB 0E3H, 0DDH, 0DDH, 0DDH, 0DDH, 0DDH, 0E3H, 0FFH ;O
DB 0DFH, 0DFH, ODFH, 0C3H, 0DDH, 0DDH, 0C3H, 0FFH ;P
DB 0E1H, 0D9H, 0DDH, 0DDH, 0DDH, 0DDH, 0E3H, 0FFH ;Q
DB 0DDH, 0DBH, 0D7H, 0C3H, 0DDH, 0DDH, 0C3H, 0FFH ;R
DB 0C3H, 0FDH, 0FDH, 0E3H, 0DFH, 0DFH, 0E1H, 0FFH ;S
DB 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0C1H, 0FFH ;T
DB 0E3H, 0DDH, 0DDH, 0DDH, 0DDH, 0DDH, 0DDH, 0FFH ;U
DB 0F7H, 0EBH, 0DDH, 0DDH, 0DDH, 0DDH, 0DDH, 0FFH ;V
DB 0EBH, 0D5H, 0D5H, 0D5H, 0D5H, 0DDH, 0DDH, 0FFH ;W
DB 0DDH, 0DDH, 0DDH, 0EBH, 0DDH, 0DDH, 0DDH, 0FFH ;X
DB 0FBH, 0FBH, 0FBH, 0FBH, 0F5H, 0EEH, 0EEH, 0FFH ;Y
DB 0E0H, 0E0H, 0E7H, 0F3H, 0F9H, 0E0H, 0E0H, 0FFH ;Z
DB 0E1H, 0DDH, 0DDH, 0E1H, 0FDH, 0FDH, 0F3H, 0FFH ;a
DB 0C3H, 0DDH, 0DDH, 0CDH, 0D3H, 0DFH, 0DFH, 0FFH ;b
DB 0FFH, 0E3H, 0DDH, 0DFH, 0DFH, 0E3H, 0FFH, 0FFH ;c
DB 0E1H, 0DDH, 0DDH, 0D9H, 0E5H, 0FDH, 0FDH, 0FFH ;d
DB 0E3H, 0DDH, 0DFH, 0C1H, 0DDH, 0DDH, 0E3H, 0FFH ;e
DB 0EFH, 0EFH, 0EFH, 0C3H, 0EFH, 0EDH, 0F3H, 0FFH ;f
DB 0E3H, 0DDH, 0FDH, 0E1H, 0DDH, 0DDH, 0E1H, 0FFH ;g
DB 0DDH, 0DDH, 0DDH, 0C3H, 0DFH, 0DFH, 0DFH, 0FFH ;h
DB 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0FFH ;i
DB 0E7H, 0D7H, 0F7H, 0F7H, 0F7H, 0FFH, 0F7H, 0FFH ;j
DB 0DBH, 0D7H, 0CFH, 0CFH, 0D7H, 0DFH, 0DFH, 0FFH ;k
DB 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0F7H, 0FFH ;l
DB 0DDH, 0DDH, 0DDH, 0D5H, 0D5H, 0D5H, 0C9H, 0FFH ;m
DB 0DDH, 0DDH, 0DDH, 0DDH, 0DDH, 0CDH, 0D9H, 0FFH ;n
DB 0E7H, 0DBH, 0DDH, 0DDH, 0DDH, 0EDH, 0F3H, 0FFH ;o
DB 0DFH, 0DFH, 0DFH, 0DFH, 0C1H, 0DDH, 0C3H, 0FFH ;p
DB 0FBH, 0F9H, 0FBH, 0E3H, 0DBH, 0DBH, 0E7H, OFFH ;q
DB 0DFH, 0DFH, 0DFH, 0DFH, 0DFH, 0CFH, 0D1H, 0FFH ;r
DB 0FFH, 0C7H, 0FBH, 0E7H, 0DBH, 0E7H, 0FFH, 0FFH ;s
DB 0F7H, 0F7H, 0F7H, 0F7H, 0C1H, 0F7H, 0F7H, 0FFH ;t DB 0E5H, 0DBH, 0DBH, 0DBH, 0DBH, 0DBH, 0FFH, 0FFH ;u
DB 0F7H, 0EDH, 0DDH, 0DDH, 0DDH, 0DDH, 0FFH, 0FFH ;v
DB 0EBH, 0D5H, 0D5H, 0D5H, 0DDH, 0DDH, 0FFH, 0FFH ;w
DB 0DDH, 0DDH, 0EBH, 0EBH, 0DDH, 0DDH, 0FFH, 0FFH ;x
DB 0FBH, 0F9H, 0EEH, 0FAH, 0F8H, 0EEH, 0EEH, 0FFH ;y DB 0E0H, 0F3H, 0F9H, 0FCH, 0E0H, 0FFH, 0FFH, 0FFH ;z DB 0C3H, 0BDH, 066H, 05AH, 07EH, 05AH, 0BDH, 0C3H
DB 03CH, 042H, 099H, 0A5H, 081H, 0A5H, 042H, 03CH
DB 0C3H, 0BDH, 05AH, 066H, 07EH, 05AH, 0BDH, 0C3H
DB 0FFH, 0F7H, 073H, 0B1H, 080H, 0B1H, 073H, 0F7H
DB 000H, 018H, 03CH, 07EH, 0FFH, 0FFH, 0E7H, 042H
END
waja28
Newbie level 2
i want to know, have u finish ur program..
i would like doing this project, could u send the right codes
welove8051
Full Member level 6
india
hey joe there are lot of logical errors in ur code. explain ur concept briefly.
incomplete_jerin
Advanced Member level 2
INDIA
Could you post the errors which you faced while compiling the code?
Regards,
Jerin.
waja28
Newbie level 2
I give u error dan assembly code. Plzz help to correct the error
  • L10008.TXT
  • ERROR.doc
  • assignment_178[1].pdf
