Urgent Help needed on 8051..
jayant.shrivastava
Newbie level 1
tmod in timer 2
hey guys... below is my program for displaying the RPM count from the gear tooth sensor mounted on the flywheel of the engine. I am unable to set the register properly for overflow count and also I am not sure if I am getting proper results at the serial display....
I have written this program recently and have to be able to execute on the hardware in 2 weeks from now!... there are no errors as such in the program.
I need ur help urgently!!!!! can you just let me know if the program is right or do i have to make any changes....?????
I also have include PWM using PCA modules... is it possible for me to do that....
this PWM will be control the throttle position by the help of electro-magnetic solenoid valve...I am using timer 2...and im not sure which value to load into the count... should it be RCAP2L or somethings else???
this is the program I am using NXP(philips) make 8051 which has 3 timers and also a PCA module for PWM etc,... plzz help!!!! I will be displaying the RPM serially for every 1 second, but I think even that part by initializing the timer0 interrupt is not working properly..
#include<p89v51rx2.H>
#include <stdio.H>
#define INTERRUPT_Timer_2_Overflow 5
#define TRUE 1
#define FALSE 0
sbit Pulse_count=P1^1;
unsigned long int CountL, CountH, Count1=0; Flag_1sec, Count_Temp=0;
void Timer_2_Init(void);
void Timer_0_Init(void);
void RPM_Display_At_Controller_End(void);
void RPM_Display_At_User_End(void);
void Serial_Init(void);
void Serial_Display(void);
void main(void)
Timer_2_Init();
Serial_Init(); // Set up Timer 2
EA = TRUE; // Globally enable interrupts
while(1)
if( Flag_1sec == TRUE)
Flag_1sec = FALSE;
Count1 = (CountH-CountL)+(Count_Temp);
RPM_Display_At_Controller_End();
RPM_Display_At_User_End();
T2MOD = 0x0C9;
T2CON = 0x04; // Load Timer 2 control register
TH2 = 0xFC; // Load Timer 2 high byte
TL2 = 0x65; // Load Timer 2 low byte
RCAP2L = 0x65; // Load Timer 2 reload capt. reg. low byte
RCAP2H = 0xFC; // Load Timer 2 reload capt. reg. high byte
CountL = RCAP2L;
CountH = RCAP2H;
C_T2 = 1; // Set the counter
CP_RL2 = 1;
EXEN2 = 1,
ET2 = 1; // Timer 2 interrupt is enabled, and ISR will be called whenever the timer overflows
TR2 = 1; // Start Timer 2 running
static void Feedback (void) interrupt INTERRUPT_Timer_2_Overflow
TF2=0;
CountL++;
CountH--;
Count_Temp++;
//EXF2=0;
