Urgent help needed about Layout!!
berko3000
Member level 3
Hi guys,
I have a problem with the simulation of my full adder cell layout. I drawed its layout in Magic but when I try to simulate it using Hspice and Awanwaves I'm getting spikes which I circled in red in this link:
[url]https://img166.imageshack.us/img166/8391/spikeeh3.jpg[/url]
How can I fix it?
thanks
Rob B
Full Member level 4
The glitches (spikes) will be due to transition times from 0~1 and 1~0 in your design.
It is not possible to get from a low logic state to a high logic state without some time passing. As seen in the waveforms at the bottom of the picture, the transitions take time.
Transition can be set to a minimum in some simulation software to provide nice-looking simulation graphs but does not reflect what really happens. Capacitance can be the cause.
I think additional logic can be added to remove the glitches.
berko3000
Member level 3
so which capacitance should I check ? The load capacitance at the output of the sum signal?
Rob B
Full Member level 4
I'm not totally sure (as I've only had an introduction to some bits of VLSI) but parasitic capacitance depends on the technique used to develop the circuit and its silicon layout.
