I have a UPS whose battery is 12v, 7.2 AH sealed lead acid battery. The battery is damaged.
Now I want to replace that battery with lead acid car battery. So that I can add lights, fan, laptop charger etc instead of desktop computer. And I also expect it to support for more than an hour.
Now, is there any problem if I add that car battery (12v)?
You can do it, but the problems I can see are: battery charger in the UPS is design for the 7.2AH capacity batteries not for higher capacity (so it will take tooooo much time to charge), second the inverter portion is not design for longer time, I mean heat sink, tracks or some wires may be, etc etc.
Multiply a factor 0.7 (approx). i.e 650VA means a 455W.
If it is a branded UPS (like APC etc) than it may be a problem (you have to give it a try and see), because they normally test and garranty the unit accounding to the battery capacity used by them.
However I have even change a APC unit for longer operation, it worked fine (I only double its heatsink size.
