Updating PadsLayout with Orcad Netlist
hooman
Junior Member level 1
Hi, I have imported an orcad netlist to PadsLayout, and placed so many parts I wan t to know how to update my design with a newer orcad netlist. I also want to know if there is anyway to save a do file of my placement to prevent placeing each time, this can be done in specctra.
Thanks.
Beepster
unknown
In Pads-Layout, under Tools, Compare/ECO, Browse (select .ASC filetype) select the netlist.asc and it will make a ECO file to import.
File, Import (file type to .eco)...
Be carfull, read the ECO first to see if it makes sense.
Good luck
sigint
Full Member level 6
State of total unemployment
You will more than likely receive an error using Orcads netlister - go to w*w.pcbstandards.com in the forum section - resources - you will find a netlister for Pads - follow the directions, the Orcad netlister ascii header is incorrect.
SiGiNT
skywalker
Earth
hooman,
wich release of Or*Cad Cap*ture you use ? If you have a release 9xx, follow the instruction of Sigint.
If you have a release 10, no problem and follow the right info of Beepster, Skywalker.
skywalker
Earth
Sigint,
are you sure ? I have asked a friend, he tell me header are ok, and no problem to generate netlist to Ca*p*ture 10.2 to Pa*ds La*y*out.
Skywlker.
sigint
Full Member level 6
Could be because we are still using Pads 5.1, but I don't think so, the file header from Orcad 10.2 simply says -
*PADS-PCB*
It should look more like -
!PADS-POWERPCB-V4.0-MILS! DESIGN DATABASE ASCII FILE 1.0
But, if it works, I wouldn't worry about it.
SiGiNT
skywalker
Earth
Sigint,
after select pads*pcb.dll for netlist, then select in option 'create*pads*bga* netlist'.
Using or*cad 10.2 off course, the header are ok.
Try it and let me know, Skywalker.
