Update ZigBee firmware
southafrikanse
Junior Member level 1
Amora, Portugal
Hello
I've been googling around to find a good way to update my ZigBee firmware. However, all the options I've seen didn't work.
I even tried to follow the datasheet which says:
"Minimum pin connections to update firmware: VCC, GND, DOUT, DIN, RTS, DTR"
But I still can't update it using X-CTU from Digi.
The develpment kit is a liitle expensive for me and I need to update my ZigBee models because I want to get AES encryption in my XBee network I'm doing.
My XBee model is XB24-ACI-001.
PS: Maybe I have the voltage levels different? The datasheet is not clearly enough.
