up/down counter using half adder ?
truebs
Full Member level 5
Asia
half adder counter
Hello friends..
can you tell me something about designing a up down counter using only half adders (and flip flops) say for 4 bit ?
VHDL code would also do ...or a logic diagram or a link....?
thanks....
tarkyss
Full Member level 6
China
counter with half adders
how many half adders?
two half adders are equal with a full adders,
only one half adders?
truebs
Full Member level 5
Asia
couter using half adder
any number would do....the aim is to create a 4 bit up/down counter using half adders...(it would need 4 as far as i know)
tarkyss
Full Member level 6
China
counter half adder
you can use two half adders to consist of a full adder
then use full adder to build your counter
anjali
Full Member level 3
implementing counter using adder
full adder = half adder + half adder
to implement up counter, pass present count + 1
& we have to store the present count ie register the present count, which is initially 0.
in this way, we can implement up counter.
to implement down counter, present - 1
we can implement subtractor with an adder, with inputs, operand1 & !(operand2)
implementation of up/down counter:
let control signal = 0 for addition,
= 1 for subtraction.
then inputs for the counter are, operand1 & XOR(operand2 , control signal).
