Up counter or down counter
stanford
Full Member level 2
between an 8 bit up counter and a down counter, which synthesizes into smaller hardware?
KlausST
Super Moderator
Staff member
I assume you get much faster a reliable result when you do a simple test.
Draw an UP counter and compile it.
Draw a DOWN counter and compile it.
Check the difference.
Klaus
dpaul
Advanced Member level 5
Germany
If you are NOT using your custom Adder or Subtractor block (allow the synthesis tool to infer the hardware), it shouldn't be a worry.
