The spreadsheet should be showing you spurs, see here:
Your actual mixer may result in low spurs, but the spreadsheet cannot predict that of course.
Also, bear in mind that the VCO signal will also have some (probably a lot!) of harmonic content.
You can filter that out of course beforehand.
I'm guessing you want to construct a test RF generator for 0-30MHz, right?
This will probably be fine, for normal use-cases. I was planning to build a sig-gen at some stage too,
but I was going to just construct many VCOs and filters, and just switch between them.
The mixer method may be better but I did not consider it for my limited frequency range need.
