Rocky&Bulwinkle
Newbie level 3
- Joined
- May 9, 2013
- Messages
- 3
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- Frostbite Falls Minnesota
- Activity points
- 1,302
I am working with an SP490E - RS-485 driver/receiver. I am looking for feedback on what to do with the unused Receiver Inputs, do I tie them high or low? The data sheet states the recievers are equipped with a "fail-safe" guaranteeing a high state if left unconnected. This PCB is not cramped for space so PU's would not be a problem. any recommendations from the design community?
Data Sheet:
The receivers for both the SP490E and SP491E have differential inputs with an input sensitivity as low as ±200mV. Input impedance of the receivers is typically 15kΩ (12kΩ minimum). A wide common mode range of -7V to +12V allows for large ground potential differences between systems. The receivers for both the SP490E and SP491E are equipped with the
fail-safe feature. Fail-safe guarantees that
the receiver output will be in a high state when the input is left unconnected.
Data Sheet:
