darshankumar
Newbie level 6
hello every one,I have written a code for AES using verilog .I am getting desired output in model sim with the same code.I have to dump on FPGA .In order i am using xilinx 10.1,it is giving error and the code is below.
module test(output[127:0]y,input clk1);
The errors displaying are...
Please help me ....
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 reg clk; reg rst; reg [383:0] tv[512:0]; wire [383:0] tmp; reg kld; wire [127:0] key, plain, ciph; wire [127:0] text_in; wire [127:0] text_out; wire [127:0] text_out2; reg [127:0] text_exp; wire done, done2; integer n, error_cnt; initial begin kld = 0; clk = 0; rst = 0; error_cnt = 0; repeat(4) @(posedge clk); rst = 1; repeat(20) @(posedge clk); tv[0]= 384'h000000000000000000000000000000009798c4640bad75c7c3227db910174e72a9a1631bf4996954ebc093957b234589; tv[1]= 384'h0000000000000000000000000000000096ab5c2ff612d9dfaae8c31f30c42168ff4f8391a6a40ca5b25d23bedd44a597; for(n=0;n<1;n=n+1) begin @(posedge clk); #1; kld = 1; @(posedge clk); #1; kld = 0; @(posedge clk); while(!done) @(posedge clk); if(text_out != ciph | (|text_out)==1'bx) begin error_cnt = error_cnt + 1; end while(!done2) @(posedge clk); if(text_out2 != plain | (|text_out2)==1'bx) begin error_cnt = error_cnt + 1; end @(posedge clk); #1; end repeat(10) @(posedge clk); end assign tmp = tv[n]; assign key = kld ? tmp[383:256] : 128'hx; assign text_in = kld ? tmp[255:128] : 128'hx; assign plain = tmp[255:128]; assign ciph = tmp[127:0]; always #5 clk = ~clk; aes_cipher_top u0( .clk( clk ), .rst( rst ), .ld( kld ), .done( done ), .key( key ), .text_in( text_in ), .text_out( text_out ) ); aes_inv_cipher_top u1( .clk( clk ), .rst( rst ), .kld( kld ), .ld( done ), .done( done2 ), .key( key ), .text_in1( text_out ), .text_out( text_out2 ) ); assign y=text_out2; endmodule
ERROR:Xst:850 - "asasd.v" line 24: Unsupported Event Control Statement.
ERROR:Xst:850 - "asasd.v" line 26: Unsupported Event Control Statement.
ERROR:Xst:2634 - "asasd.v" line 32: For loop stop condition should depend on loop variable or be static.
ERROR:Xst:850 - "asasd.v" line 61: Unsupported Event Control Statement.
Please help me ....
