[ARM] "unsigned char" is always true ....?
bianchi77
California
Guys,
What should I change for fixing :
Warning : comparison of constant 49152 with expression of type "unsigned char" is always true ....?
the line is :
while(Mp3ReadRegister(0x03) != CLOCK_REG)
unsigned char Mp3ReadRegister( unsigned char addressbyte)
#define CLOCK_REG       0xc000
Thanks
The simple fact is the following conditional is always true:
How can a type of unsigned char with a maximum value of 0xFF, ever equal 0xC000?
It obviously cannot.
The only way the above conditional makes sense is if your defined value of CLOCK_REG is within the range of an unsigned char, 0x00 to 0xFF.
BigDog
What variable type should I use then ? what's your suggestion ? thanks
How could we know?
Either the function prototype or the constant definition is erroneous.
unsigned long Mp3ReadRegister( unsigned long addressbyte)
O.K., but what's inside the function body? How's the return value derived? Is it a 16-bit register read result? With an ANSI C compiler, a 16-bit value would have the type unsigned, not unsigned long.
I don't understand why you have changed the address type, too.
the function :
	int resultvalue = 0;
	Mp3DeselectData();
	Mp3SelectControl();				//XCS = 0
	uint8_t data7[2] = { VS_READ_COMMAND, addressbyte };
	HAL_SPI_Transmit(&hspi1,data7,2,1000);
	uint8_t data8[1] = {0x00};
  data8[0] = 0;
	HAL_SPI_Receive(&hspi1,data8,1,1000);
	resultvalue = data8[0];
	resultvalue <<= 8;
	resultvalue += data8[0];
	Mp3DeselectControl();
	return resultvalue;           	//??16??????
Please correct me if I'm wrong ? thanks
probably
unsigned int Mp3ReadRegister( unsigned char addressbyte)
will be enough
