[SOLVED] Unsigned and Signed Addition and subtraction VHDL
raguna
Junior Member level 3
Earth
Hi all!
I am trying to design an ALU which does signed addition & subtraction and unsigned addition & subtraction. I have following code written, but does not work.
For unsigned : I used simple R<= A+B and R<= A-B; for addition and subtraction
For Signed: I tried to change the type of A,B to Signed and perform addition. And I am not sure how to check for overflow/underflow. Can someone please help me in this?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity lab5 is
 port(CLK: in std_logic;
 A,B : in std_logic_vector(15 downto 0);
 R : out std_logic_vector(15 downto 0);
 Overflow : out std_logic);
end lab5;
architecture archi of lab5 is
 signal  tmp : std_logic_vector( 16 downto 0);
 variable sgnA, sgnB : SIGNED (16 downto 0);
 variable sgnout : SIGNED (16 downto 0);
 variable usgnA, usgnB: UNSIGNED (16 downto 0);
 variable usgnout : UNSIGNED (16 downto 0);
 begin
 process (CLK)
 begin
	sgnA := signed(A'high+1 downto 0);
	sgnB := signed(B'high+1 downto 0);
	usgnA := unsigned(A);
	usgnB := unsigned(B);
	if (CLK'event and CLK='1') then
		if(AluOp = "00000") then
		{R <= A + B; --Unsigned addition
		 Overflow <= A(15) and B(15);}
		elsif(AluOp = "00001") then
			{R <= A-B; --treating A & B as unsigned integers
			 Overflow <= (A<B)?1:0; -- For underflow case 	}
		elsif(AluOp = "00010") then
			{sgnout=sgnA-sgnB;--treating A & B as unsigned integers
				R <= std_logic_vector(sgnout);	--Not sure how to do overflow in signed}
		elsif(AluOp = "00011") then
				R <= std_logic_vector(sgnout);	}
Quick hints:
Use syntax tags for your code:
Define "but does not work" , we do not read minds.
Include your testbench that you didn't write, and screenshot of running the testbench that you didn't write.
easiest way to check for over/underflow - add an extra bit to the input operands, and then check the overflow bit in the result:
unsigned:
op <= ('0' &a) + ('0' & b);
overflow = op(MSB);
similarly for signed, extend the sign bit (use the resize function), check the new MSB, and then check the MSB of the two inputs to check for over/underflow.
op <= resize(a, op'length) - resize(b, op'length);
Hi TrickyDicky!
Thanks for your reply. I am having a syntax problem saying,"Can't determine the definition of operator "+""
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
--use IEEE.STD_LOGIC_ARITH.ALL;
--use IEEE.STD_LOGIC_SIGNED.ALL;
--use IEEE.STD_LOGIC_UNSIGNED.ALL;
 entity ALU16 is port
 ( A: in std_logic_vector (15 downto 0);
 B: in std_logic_vector (15 downto 0);
 AluOp: in std_logic_vector (4 downto 0);
 shamt: in std_logic_vector (2 downto 0);
 Zero: out std_logic;
 Overflow: out std_logic;
 R: out std_logic_vector (15 downto 0)
 end ALU16;
 architecture RTL of ALU16 is
 signal  temp : std_logic_vector( 16 downto 0);
 signal usgnA, usgnB, Reg1 : unsigned(15 downto 0);
 signal sgnA, sgnB, Reg2 : signed(15 downto 0);
 begin
 process(AluOp)
 variable p : integer range 0 to 15;
 begin
--usgnA <= unsigned(A);
--usgnB <= unsigned(B);
sgnA <= signed(A);
sgnB <= signed(B);
 case AluOp is
	when "00000" =>
		--Reg1 <= usgnA + usgnB;
		temp <= ('0' & A) + ('0' & B);
		Overflow <= temp(16);
		--temp <= A + B;
		R<=temp(15 downto 0);
		--Overflow <= A(15) and B(15);
--	when "00001" =>
--		--Reg1 <= usgnA - usgnB;
--		R<=A-B;
--		if (A < B) then Overflow<= '1';
--		else Overflow<= '0';
--		end if;
--	when "00010" =>
--		Reg2 <= sgnA + sgnB;
--		R<=std_logic(Reg2);
--		Overflow <= A(14) and B(14);
--	when "00011" =>
--		R <= sgnA - sgnB;
--		if (sgnA < sgnB) then Overflow<= '1';
--		end if;
--	when "00100" =>
--		if(A < B) then
--		R <= "1111111111111111";
--		else
--		R<= "0000000000000000";
--		end if;
--		when "00101" =>
--			 for i in 0 to 15 loop
--				R(i)<= A(i) and B(i);
--				end loop;
--		when "00110" =>
--				R(i)<= A(i) or B(i);
--				end loop;
--		when "00111" =>
--				R(i)<= not (A(i) or B(i));
--				end loop;
--		when "01000" =>
--				R(i)<= (A(i) xor B(i));
--				end loop;
--		when "01001" =>
--				R(i)<= not A(i);
--				end loop;
--		when "01010" =>
--			 	temp <= A;
--				temp <= shift_left(A,to_integer(shamt));
--				p :=to_integer(shamt);
--				for i in 1 to 3 loop
--				temp(i-1) <= '0';
--				end loop;
--				R<= temp;
--		when "01011" =>
--			 	temp <= A;
--				temp <= shift_right(A,to_integer(shamt));
--				end loop;
--				R<= temp;
--		when "01100" =>
--			 	temp <= A;
--				temp(i-1) <= A(15);
--				end loop;
--				R<= temp;
	when others =>
		NULL;
--	if( R = "0000000000000000" ) then
--			Zero <= '1';
--		else Zero <='0';
--		end if;
 end case;
 end process;
end RTL;
there is no definition of + or - for std_logic_Vector cast it to unsigned as TrickyDicky said
hai, im newbie....any idea for this..?
ARCHITECTURE beza OF beza IS
BEGIN
PROCESS (clk)
variable d : integer := 2;
variable a : integer := 5;
variable b : integer := 7;
BEGIN
IF clk'EVENT AND clk='1'THEN
c<=(a-b) / d;
the output should be -1.. but i got 1.
and if i change variable a into 3 and variable b into 9 the output from simulation is 253.. it should be -3
may someone help me
may someone help me
According to your second case the first case output should be 255 check once.Actually 253 (binary) is the 2's complement of 3 which is equal to -3.better change radix representation to signed in your simulation.
LIBRARY ieee;
USE ieee.All;
ENTITY beza IS
PORT (
clk : IN bit;
c : OUT integer RANGE -127 TO 127
END beza;
BEGIN
PROCESS (clk)
BEGIN
c<=(a-b) / d;
END IF;
END PROCESS;
END beza;
sory i dont get it..
here my full coding
I doubt this is your full code because it has many syntax errors.
Also - you have a testbench for this?
no.. because i run this code in quartus version 8.1
there is no error in the simulation
hmm
sory.. i send wrong code.. this is the actual one
sory.. this is the correct one...[/QUOTE]
LIBRARY ieee;
USE ieee.All;
ENTITY beza IS
PORT (
clk : IN bit;
END beza;
BEGIN
PROCESS (clk)
BEGIN
c<=(a-b) / d;
END IF;
END PROCESS;
END beza;
Please be clear.
Your origional post said you had problem in simulation. Now you say the simulation is fine - so what is not working?
i mean the simulation doesnt show any error.. but the output is not what i want..
for ie :
c<= (a-b)/d
the output should be -1 if
but in simulation it shows 1. it should be -1
and if i change :
variable a : integer := 3;
variable b : integer := 9;
it should be -3.. but simulation shows 253
Please post your waveform.
Btw, 253 is -3 in 2s compliment.
the first waveform is when the variable
d=2
a=5
b=8
and the second wavedorm is when the variable
d=2
a=3
b=9
As i said it is showing 255 in first case and 253 in second case.In order to convert them to required values -1 and -3 respectively.Right click on the output variable in the simulation waveform editor one pop up window appears choose radix to signed decimal and then re run simulations...
