Unknown formal identifier in VHDL
sarmadmahmood969
Newbie level 1
I have a VHDL code in which I call different modules. Here I god error that unknown formal identifier. I don't know how to tackle this error. I am new in VHDL, I put so much of my time but not succeeded. Here is the code:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
--                  Copyright (C) 2014 Altera Corporation                      *
-- ALTERA, ARRIA, CYCLONE, HARDCOPY, MAX, MEGACORE, NIOS, QUARTUS & STRATIX    *
-- are Reg. U.S. Pat. & Tm. Off. and Altera marks in and outside the U.S.      *
-- All information provided herein is provided on an "as is" basis,            *
-- without warranty of any kind.                                               *
-- Module Name: mult8x8                        File Name: mult8x8.vhd          *
-- Module Function: This file contains the top level module for the            *
--                  8x8 multiplier                                             *
-- REVISION HISTORY:                                                           *
-- Insert library and use clauses
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
-- Begin entity declaration for top-level "mult8x8"
ENTITY mult8x8 IS
    -- Begin port declartion
    PORT (
        -- Declare control inputs "clk", "start" and "reset_a"
        clk, start, reset_a : IN STD_LOGIC;
        -- Declare data inputs "dataa" and "datab"
        dataa, datab : IN UNSIGNED(7 DOWNTO 0);
        -- Declare multiplier output "product8x8_out"
        product8x8_out : OUT UNSIGNED(15 DOWNTO 0);
        -- Declare seven segment display outputs
        seg_a, seg_b, seg_c, seg_d, seg_e, seg_f, seg_g, done_flag : OUT STD_LOGIC
-- End entity
END ENTITY mult8x8;
--  Begin architecture
ARCHITECTURE logic OF mult8x8 IS
    -- Declare all lower level components
    COMPONENT adder
        PORT (
            dataa, datab : IN UNSIGNED (15 DOWNTO 0);
            sum : OUT UNSIGNED (15 DOWNTO 0)
    END COMPONENT adder;
-- complete component instantiations
-- the components were created in the prior labs
--- YOUR LOGIC HERE ----
    COMPONENT mult4x4
        PORT(
            dataa, datab : IN UNSIGNED(3 DOWNTO 0);
            product : OUT UNSIGNED(7 DOWNTO 0)
    END COMPONENT mult4x4;
    COMPONENT mux4
        PORT(
            mux_in_a, mux_in_b: IN UNSIGNED(3 DOWNTO 0);
            mux_sel : IN STD_LOGIC;
            mux_out : OUT UNSIGNED(3 DOWNTO 0)
    END COMPONENT mux4;
    COMPONENT shifter
            Port (
                input: IN UNSIGNED (7 DOWNTO 0);
            shift_cntrl : IN UNSIGNED (1 DOWNTO 0);
            shift_out : OUT UNSIGNED (15 DOWNTO 0)
    END COMPONENT shifter;
    COMPONENT counter
        PORT (
            clk, aclr_n : IN STD_LOGIC;
            count_out : OUT UNSIGNED (1 DOWNTO 0)
    END COMPONENT counter;
    COMPONENT mult_control
        PORT (
            clk, reset_a, start : IN STD_LOGIC;
            count : IN UNSIGNED (1 DOWNTO 0);
            input_sel, shift_sel : OUT UNSIGNED(1 DOWNTO 0);
            state_out : OUT UNSIGNED(2 DOWNTO 0);
            done, clk_ena, sclr_n : OUT STD_LOGIC
    END COMPONENT mult_control;
    COMPONENT seven_segment_cntrl
        Port ( input : in  UNSIGNED (2 downto 0);
                   seg_a : out  STD_LOGIC;
                   seg_b : out  STD_LOGIC;
                   seg_c : out  STD_LOGIC;
                   seg_d : out  STD_LOGIC;
                   seg_e : out  STD_LOGIC;
                   seg_f : out  STD_LOGIC;
                   seg_g : out  STD_LOGIC);
    END COMPONENT seven_segment_cntrl;
    COMPONENT reg16
        Port(
            clk, clk_ena, sclr_n : IN STD_LOGIC;
            datain: IN UNSIGNED (15 DOWNTO 0);
            reg_out : OUT UNSIGNED (15 DOWNTO 0)
    END COMPONENT  reg16;
    -- Declare internal signals to use as wires to connect blocks
    -- used these signals to connect up all the components
    -- you should not need anymore signals
    SIGNAL aout, bout : UNSIGNED(3 DOWNTO 0);
        SIGNAL product : UNSIGNED(7 DOWNTO 0);
    SIGNAL shift_out, sum, product8x8 : UNSIGNED(15 DOWNTO 0);
    SIGNAL count, shift : UNSIGNED(1 DOWNTO 0);
    SIGNAL state_out : UNSIGNED(2 DOWNTO 0);
    SIGNAL clk_ena, sclr_n, start_n : std_logic;
    SIGNAL sel : UNSIGNED(1 DOWNTO 0);
BEGIN
    -- Start SIGNAL requires inversion before connecting to counter
    start_n <= not(start);
    -- Connect blocks per schematic in the lab manual
    -- this port map is completed
    u1: mux4 PORT MAP (mux_in_a => dataa(3 DOWNTO 0),
                       mux_in_b => dataa(7 DOWNTO 4),
                       mux_sel => sel(0),
                       mux_out => aout(3 DOWNTO 0));
    u2: mux4 PORT MAP (mux_in_a => dataa(3 DOWNTO 0),
                       mux_sel => sel(0),
    u3: mult4x4 PORT MAP (aout => dataa (3 DOWNTO 0),
                  bout => datab (3 DOWNTO 0),
                       product => product(7 DOWNTO 0));
    u4: shifter PORT MAP (product => input (7 DOWNTO 0),
                    shift => shift_cntrl (1 DOWNTO 0),
                    shift_out => shift_out (15 DOWNTO 0));
    u5: counter PORT MAP (clk => clk,
                  start => aclr_n,
                    count => count_out (1 DOWNTO 0));
    u6: mult_control PORT MAP (clk => clk,
                   reset_a => reset_a,
                   start => start,
                   count => count (1 DOWNTO 0),
                    sel => input_sel (1 DOWNTO 0),
                    shift => shift_sel (1 DOWNTO 0),
                    state_out => state_out (2 DOWNTO 0),
                    done => done,
                    clk_ena => clk_ena,
                    sclr_n => sclr_n);
    u7: reg16 PORT MAP (clk => clk,
                clk_era => clk_ena,
                sclr_n => sclr_n,
                sum => datain (15 DOWNTO 0),
                    product8x8 => reg_out (15 DOWNTO 0));
    u8: adder PORT MAP (shift_out => dataa (15 DOWNTO 0),
                product8x8 => datab (15 DOWNTO 0),
                    sum => sum (15 DOWNTO 0));
    u9: seven_segment_cntrl PORT MAP (state_out => input (2 downto 0),
                        seg_a => seg_a,
                        seg_b => seg_b,
                        seg_c => seg_c,
                        seg_d => seg_d,
                        seg_e => seg_e,
                        seg_f => seg_f,
                        seg_g => seg_g);
    product8x8_out <= product8x8;
-- End architecture
END ARCHITECTURE logic;
This is the error:
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(151): (vcom-1484) Unknown formal identifier "aout".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(152): (vcom-1484) Unknown formal identifier "bout".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(155): (vcom-1136) Unknown identifier "input".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(156): (vcom-1136) Unknown identifier "shift_cntrl".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(155): (vcom-1484) Unknown formal identifier "product".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(156): (vcom-1484) Unknown formal identifier "shift".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(160): (vcom-1136) Unknown identifier "aclr_n".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(161): (vcom-1136) Unknown identifier "count_out".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(160): (vcom-1484) Unknown formal identifier "start".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(161): (vcom-1484) Unknown formal identifier "count".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(167): (vcom-1136) Unknown identifier "input_sel".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(168): (vcom-1136) Unknown identifier "shift_sel".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(170): (vcom-1136) Unknown identifier "done".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(167): (vcom-1484) Unknown formal identifier "sel".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(168): (vcom-1484) Unknown formal identifier "shift".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(177): (vcom-1136) Unknown identifier "datain".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(178): (vcom-1136) Unknown identifier "reg_out".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(175): (vcom-1484) Unknown formal identifier "clk_era".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(177): (vcom-1484) Unknown formal identifier "sum".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(178): (vcom-1484) Unknown formal identifier "product8x8".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(181): (vcom-1484) Unknown formal identifier "shift_out".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(182): (vcom-1484) Unknown formal identifier "product8x8".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(187): (vcom-1136) Unknown identifier "input".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(187): (vcom-1484) Unknown formal identifier "state_out".
** Error: E:/Fiverr/VHDL/VHDLCounterMultiplier/ModelSimdo/mult8x8.vhd(201): VHDL Compiler exiting
If you please help me to resolve the error. I will be very thankful to you.
You should declare components for entities you have already. If not, then that might be the problem.
Moreso in your port map, I noticed that you mapped signals to the ports of components. That's not acceptable. You should map the ports of components to the ports of the entities that your are instantiating.
Im not really sure what this means? All component declarations are present. But actually, if all sources are in VHDL, then components are not needed at all, and can actually slow down your compilation. Direct instantiation would be much preferable. That can be done like this:
some_inst: entity my_lib.my_ent
port map (
  -- map ports etc
@OP. You have several port mappings the wrong way around. The port name from the component should be on the LHS, with the signal you are mapping it to on the RHS. THe first two mux4 instantiations are correct, but the rest are wrong.
We are in the same line of argument. The OP declared components for entities he didn't create. It's not supposed to be so.
He declared signals and mapped the signals to ports of the components. Components are basically lower level entities declared for use in a top level entity. Ports of components instances should be mapped to ports of components...which is basically mapping them to ports of those lower level entities declared for use at the top level.
A component is just a declaration of a component. Ports from a component can be mapped to any signals. They do not need to connect to ports or other components,, they are just signals to be used.
Components are mapped to entities during the elaboration phase.
"(vcom-1484) Unknown formal identifier" indicates that the LHS of a port association in the instantiation doesn't exist. The error message is the same if you are instantiating components or design entities directly.
