Unknown Component - FOQ HS-524 W7057A47
diamadiss
I found this component but I don't know and I can't find a datasheet for what exactly is. I believe that is a crystal but I am not sure. The code that is written on the box is "FOQ HS-524 W7057A47". Does anyone know what is it?
Yes I think that it is a 30Mhz oscillator by NEL Frequency Controls, Inc I can't find the data sheet for it but I think that it is a 5V type as there is no "A" before the 5. The part number is HS-524 The HS means four leads.
In the picture the lettering does not look like HS-524, it looks more like HS-150 which is easy to find the data sheet for.
Hi. Thanks for the reply. I look it again and on the chip (not in the box) write FOQ "HS 156". I can't find a datasheet. If I use the pin out from the HS-150 oscillator I will damage it if it is not the same as "HS-150"?
The data sheet for the HS-150 would apply to the HS-156, I think that the end 6 denotes the tolerance, which is user specified.
