I have measured the voltage of all vcc pins. they are correct. but some IO pins have strange values. for example the voltage of them is 1.5 v.
here is my schematic:
Which pin(s) show 1.5V?
FYI TDI of the Xilinx USB platform cable is an output of the pod and and input for the FPGA, TDO is an input to the Xilinx USB platform cable and an output of the FPGA. If you switch them TDO(cable)-TDI(fpga) and TDI(cable)-TDO(fpga) then I would expect to see 1.5V when they are in contention.
thanks for comment. I have used a 4.7 k ohm resistor for pulling up HSWAPEN pin. now I changed it with a 330 ohm resistor and all of them are 0 volt.
in ug380 it is written that:
If JTAG is the only configuration mode, then PROGRAM_B, INIT_B, and DONE can be
tied High to a 330Ω resistor.
I also tried this configuration. but I still receiving the same message.
