boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
The first part of this circuit up to the 2200uF caps works well. From a 24VAC wall plug I can get -36VDC and +36VDC unregulated. I can then pass these through my LM317 and LM337 voltage regulators to get -18VDC and +18VDC.
But what's with the 36V? I can't conceptualise how the 24VAC is ending up as +/-36VDC.
I know the capacitors 'fill in' the gaps between the voltage humps after the AC passes through the half bridge rectifier. But how is the AC voltage being almost doubled as DC?
Also, if I was to build an adjustable voltage source with this system, how would you go about adding a digital display to show the voltage? Has anyone come across an easy to understand webpage on this?
