Universal infrared remote control receiver with 89c2051
mip
Member level 2
transceiver ir code for 2051
Hi @ll,
I would like to build a universal infrared remote control receiver into a hobby grade project based on Atmel 89c2051.
There are many projects based on PIC controllers as UIR (12c509 and 16f84), UIRt, IRMan and others.
These devices receive IR and calculate a 6byte value which is unique to every key beeing sent.
There are no sources available for these projects :( , but as there's also a project based on PIC12c509, it can't be too hard.
I tried metering the time between pulses, identifying them as hi/lo, but I don't know how to limit received values with different lengths to a fixed unique value (kind of checksumming or simply shift bits into a circular buffer?). Additionally, some remotes have a bit that gets toggled on every send.
I don't want to decode (which would be limited to a few remotes talking know protocols like RC5, RECS80, Sony), I want to keep it as universal as possible.
Can somebody please tell me a good algorithm or show me sources?
usbman
Germany
rc5 ir code using at89c2051
At least for RC5 there is a c source at www.8052.com.
Check the codelib there.
usbman
Reactions: gun
    gun
mip
Member level 2
89c2051
thx, but I'm currently doing RC5 which limits my application to just a few remotes.
As I said above, I would like to do it in a universal way.
Fragrance
East Of Earth
remote sony + 89c2051
Freind please find this i think this is useful
regards
Reactions: gun
    gun
Fragrance
East Of Earth
rc5 bascom 8051
regards
Fragrance
East Of Earth
remote control 89c2051
Freind i am sedning you this file i hope this will be use ful for you
regards
Fragrance
East Of Earth
universal ir remote decoder
regards
buts101
Full Member level 3
bascom infrared remote control
hello there..
i need a program code to decode rc5 sony remote control . i want to use 8051 uc but i found decoder code for 2051 uc for easytip1 code 718 from this site **broken link removed**
i can't find the technical detail of easytip remote control or find code for 8051 deocder sony rc5 code
plz help me to sort out the problem
thank you
mgajo
Full Member level 2
universal ir remote receiver
Hi
RC5 is standard
Its same for Sony RC5 ,Philips RC5 or XX RC5.
Easy way to use RC5 and 8051 is to use Bascom 8051 compiler.
Just a few lines and it works
buts101
Full Member level 3
atmel remote control receiver
can u elaborate more...about "adding few lines"
Reactions: gun
    gun
vsmGuy
Advanced Member level 2
VddVss
+89c2051 +bascom
@Fragrance
Can you please reupload the file ?
Reactions: gun
    gun
JaMe
Junior Member level 1
Indonesia
attiny13 ir out bascom
I did project like that last year using ATTINY2313. It was a Universal Remote Control Transceiver. Have been tested at SONY TV, K-world TV-tunner, and a dvd player. Here's my project
born4elex
india
thanx JaMe.....great work
Reactions: gun and joco10
    joco10
    gun
