PG1995
Full Member level 5
Hi
I'm trying to understand Thevenin's thoerem through an example problem. Given below are two scans of the example problem.
1: The author says: Because of the presence of the dependent source, however, we excite the network with a voltage source Vo...
Okay, what would the author have done if there were no dependent source?
2: Why does the author choose subscripts "o" and "oc" in Vo and Voc when the author is concerned about the terminals "a" and "b" of the circuit? Why didn't the author choose more meaningful subscripts?
3: I1 = 1/6 A, I2 = -1/18 A, I3 = -1/6 A
The above currents, I1, I2, and I3, are for three loops. The circuit consists of three loops, right? The current supplied by the 1V source is assumed to be Io. This is the current being fed to the entire circuit. The authors then says Io = -I3. Why? The I3 is the current only in ONE loop which is only one part of the circuit, then how can we equate something such as Io which is being fed into the entire circuit to something which is only being fed in a part of that entire circuit?
4: The author says: 4(I1 - I2) = Vx.
Is this correct? Previously, the author has said: -4I2 = Vx = I1 - I2.
Please help me with the above queries. It would be really kind and nice of you. Thank you.
Scans
1: part one of the example:
https://img197.imageshack.us/img197/5708/theveninpart1.jpg
2: part two of the example
https://img709.imageshack.us/img709/3244/theveninpart2.jpg
Scans
