PCB Interconnects and Socket Technology
Share this group
Quick Overview
Category
Uncategorized
Language
Total members
26
Total events
Total discussions
25
Total views
34K
Total albums
Understanding Mulit-finger Contact Clips in Screw Machine Receptacles
mhoulroyd
Junior Member level 3
Levittown,NY
Typically inside every screw machine socket receptacle is a precision die stamping called a contact clip. Contact clips are usually stamped using beryllium copper (for conductivity)
or beryllium nickel (for elevated heat applications). These stampings are press-fit into machined brass shells and function as the electrical and mechanical interface to a mating pin.
Contact clips are conical in shape, and feature contact fingers, sometimes 3,4,6 or 8 depending on the contact size and force rating. The function of the contact clip fingers is:
1. Apply force to the mating pin
a. Initial insertion force: highest first force as the contact clip is plated and in pristine state.
b. 2nd insertion force: Fingers have been initially flexed, now the typical
characteristic insertion force.
c. Normal Force - the force required to hold the pin from falling out.
d. Extraction Force: the force required to disengage the pin from the clip.
Socket technology is one of those sciences that people either learn by working for a connector manufacturer, learning painfully from trial and error or telepathic communication with aliens, since this topic is not taught in any college program.
Since contact clips are made of spring material, they have a pin diameter acceptance range.
The material type and thickness determines the current capacity.
Not knowing which contact clip to specify in your socket application is the difference between application success and failure.
As a general rule of thumb, select a contact clip with a pin acceptance range that your device lead falls somewhere in the middle of.
For a device with less than 10 leads, select a socket with a contact clip that will give you sufficient retention force to hold your device.
For a device with hundreds of leads, carefully look at the characteristic insertion and extraction forces to make sure you can engage and disengage the device.
If I can help you with this topic, please feel free to contact me - Regards, Marty
[video=youtube_share;TCA51gWUpbM]http://youtu.be/TCA51gWUpbM[/video]
