Achira
Newbie level 6
- Joined
- Jul 14, 2013
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- In the faculty
- Activity points
- 82
For water it`s another opera. Different transducers-antennas, otherwise it works. Ask to submarine crew.i am an engineering undergraduate. we have a project to design under water vehicle. we want to detect the distance from the sea surface to vehicle. we try with ultra sonic sensor but it did not work.
follow sketch sows clearly what i want.
please help any one know about this......
\What about the range of distances you have to detect.
Sounds like your not familiar with sound propagation laws, particularly properties like acoustic impedance and impedance matching between different media.Why not using audible frequency range and simple speaker and mic in good water-resistant enclosures with horn on top?
Maxsonar WRC has outdoor air sensors, but no underwater sensors. I won't exclude that they can work in liquid media at short distance, but the performance is most likely poor or they'll just fail. Factor 5 higher sound speed and factor 750 higher media density demands a completely different transducer design.
Have you seen trustworthy test results? I would be a kind of "lucky coincidence" if a sensor designed for air interface achieves a similar operation range in water.I won't deny that these aren't intended explicitly for underwater use, but if one gets the outdoor IP67 (Water resistant, but not water proof) and carefully works with them to improve waterproofing, they HAVE been determined to work, empirically, for many hours by several builders of underwater robotic vehicles, and used them with quite good results, with total range of over 5 meters. Otherwise, I would not have suggested these.
