unbonded output ports
shaiko
Advanced Member level 5
What is the state of output pins that aren't bond in the FPGA UCF file ?
some_output <= '1' ; -- "some_output" is defined as an output port in the top entity but not defined in the UCF file
What will happen ?
gongdori
Full Member level 2
I think the tool picks up a pin and assign the output signal to it (the pin for the best timing, I guess?).
Reactions: shaiko
    shaiko
permute
Advanced Member level 3
yes, the tools will pick a spot at random. I really don't know who thought this was a good default, but it's what happens.
Reactions: shaiko
    shaiko
joelby
Full Member level 4
I'm not sure about the exact algorithm it applies, but it can be useful if you're planning to design a circuit board and want to let the tools fit pins in optimal locations, which can help when there are slightly non-obvious constraints (such as half bank clocking regions, I/O buffer type and voltage restrictions, etc.). There's nothing worse than building a board and finding out too late that your design can't fit the pin placement you picked.
Reactions: shaiko
    shaiko
samuraign
Full Member level 2
You have option while generting the bitfile to decide about unconnected pins either to pull-up/pull-down or floating
Reactions: shaiko
    shaiko
