unable to understand the code...
embed_v
Junior Member level 1
hiii
i have some code with structure, enum, fun plz tell me the flow of code
for understanding structure and like other stuff.
enum A_MODE{
	A = 0,
	B,
        C,
        D,
        E,
typedef struct _a_mode
	unsigned int sen;
	unsigned int state;
	unsigned int last ;
	unsigned int thick;
	unsigned int count;
	unsigned int status;
} A_MODE;
A_MODE a_modes[MAX];
int Execute(void)
 (i am including only some part of this fun. )
	case BILL_PICKING:
				switch (a_mode[slot].sen)
				case CASSETTE_A:
					sensor = SENSOR_A;
					break;
				case CASSETTE_B:
					sensor = SENSOR_B;
					break;
				if (sensor)
					a_modes[slot].state = B;
					a_modes[slot].last= TimingCount;
                                else
enum A_MODE{
A = 0,
B,
C,
D,
E,
This is a definition for an enum template called "A_MODE". This enum has five values; A,B,C,D,E. The numerical value of A is 0, numerical value of B is 1 and so on.
unsigned int sen;
unsigned int state;
unsigned int last ;
unsigned int thick;
unsigned int count;
} A_MODE;
This is a definition of structure called "_a_mode" and you create an alias (nickname) for this template called "A_MODE". You then create an array of this structure, the array is called "a_modes" and the number of elements in this array is "MAX".
int Execute(void)
case BILL_PICKING:
case CASSETTE_A:
sensor = SENSOR_A;
break;
case CASSETTE_B:
sensor = SENSOR_B;
break;
if (sensor)
else
This is switch case statement that checks for the value of the property "sen" of the structure "A_MODE" (it should be "a_modes"), and according to the value of the "sen", a different decision will be taken.
Hope this helps.
Enumerations are listed constants
Code C - [expand]
enum A_MODE{
A = 0,
B,
C,
D,
E,
A with be 0 , B=1, C=2, D=3, E=4
Structures are used to group variables under one heading or name.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
    unsigned int sen;
    unsigned int state;
    unsigned int last ;
    unsigned int thick;
    unsigned int count;
} A_MODE;
//if you declare a variable of type A_MODE which represents the above structure
A_MODE mystracture;
// then you will have all the above members, each one is an individual unsigned int variable, they are just grouped under a variable name
mystracture.sen
mystracture.state
mystracture.last
mystracture.thick
mystracture.count
mystracture.status
the next line
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
A_MODE a_modes[MAX]; // declares an array of the above structure
//then you will have:
 a_modes[0].sen
 a_modes[0].state
 a_modes[0].last
 a_modes[0].thick
 a_modes[0].count
 a_modes[0].status
 a_modes[1].sen
 a_modes[1].state
 a_modes[1].last
 a_modes[1].thick
 a_modes[1].count
 a_modes[1].status
// up to MAX-1
 a_modes[MAX-1].sen
 a_modes[MAX-1].state
 a_modes[MAX-1].last
 a_modes[MAX-1].thick
 a_modes[MAX-1].count
 a_modes[MAX-1].status
Alex
