unable to understand Synplicity pro warning
s3034585
Full Member level 4
pruning register synplicity
Hi Guys
I am using synplicify pro 7.7 for synthesis. While synthesis i am getting a warning as follows:
@W: CL169: mycode.vhd(177): Pruning Register rslt_req_ff(1)
I tried to search this on net but didnt get any info on it. Can any one please tell me about it.
Thanks in advance
tama
pruning register warning
Can you post ur code here??
i believe that the register in question is redundant and the tool has either removed or multiplexed it with some other register.
This warning occurs when the compiler or mapper detects a register fixed at a constant value, either through optimization or through constant propagation, and then removes it. In your case the register bit rslt_req_ff(1) must have been fixed at a constant value. Hence you can avoid the warning message by using the directive "syn_preserve" for the specific register. [i.e /*synthesis syn_preserve=1 */ ]
