Unable to start the DVE gui for Synopsys VSC
souvikedaboard
Newbie level 6
Newbie level 6
Hi, so I wrote the veriloge code for a counter and a testbench for it. However I am not able to start the DVE gui for it. When I am typing the dve command it keeps saying:
Error-[DVAP021] DVE
Cannot connect to X server
Please check your display setting
Any ideas about what can be done?
I tried setting DISPLAY=localhost:10.0
It didn't work either
Do you mean VCS of Synopsys as the simulation tool?
If yes...
If you are able to successfully compile your RTL and TB, then in the compilation dir, an executable named 'simv' will be created.
You can bring up the GUI by the command: ./simv -gui &
That is your DVE GUI and you can also find the DVE command prompt.
