Unable to make pic sleep for 1 minute
EgrK
Junior Member level 2
East part of world
Hellow again
i need to make the pic sleep for exactly one minute
the follwing is my unprecise code.
i have tried alot to get 1 minute sleep but could not
need help
thanks in advance
list p=16f883
#include <p16f883.inc>
i	equ 20
j	equ 21
Minutes 	equ 22
Seconds  	equ 23
movlw	b'10001000'
movwf	OPTION_REG
movlw .1	;one minute
movwf i		;i=1
call DelayiM
DelayiM	sleep
	sleep
loop_Minute	sleep
			movlw .60
			movwf Seconds
loop_Sec			sleep
					sleep
					movlw .60
					movwf j
loop_Option					sleep
						clrwdt
						decfsz	j,1
						goto loop_Option
	decfsz	Seconds,1
	goto loop_Sec
decfsz i,1
goto loop_Minute
return
END
Do you actually mean sleep (PIC power saving mode) or just a delay? For a precise delay, you'll use a timer. The available accuracy depends on your clock option, either internal oscillator (1 - 2 %) or crystal (e.g. 100 ppm). Power saving sleep mode can be only timed by watchdog timer which is less accurate.
I mean delay not power saving mode, if you look at the code you will see the OPTION_REG=b'10001000,i have used internal oscillator in configuration bits and the watch dog is set enabled (bit3=1 in OPTION_REG),if you beleive the timer is better,i still have to use watch dog because i am using it in many lines in code and several programs too ,if this will cause some minor error i have to accept it
it will be a great help if you include both solution one using watch dog and one using timer(i need to know the configuration bits too for timer)
would you please refer me to good example ,i am very novice to pic device,and it would be hard to understand any summary concerning the question
thanks
