Unable to generate output from TRANSFORMER (coupled inductor)!
jose_peeterson
Newbie level 6
hi all,
i have the following circuit. the other end of the transformer does not produce any output as shown below. can you please explain what is the problem?
Try remove C6.
Because C6 act as a high pass, which is an Open circuit in such low frequency.
It would appear the normal input is some sort of shock impulse. Since the circuit is only sensitive to high frequency AC signals try using a square-wave or pulse input to test the circuit.
