Unable to edit or delete any metal wire in Cadence virtuoso layout
im_pam
Member level 5
Member level 5
Dear all,
when i am opening my own any layout design in cadence virtuoso (version: IC_6), i am unable to edit the metal layer . Also i am not able to delete it and made no setting . Can anyone please help what happened and how to edit the layout design?? Earlier it was working fine.
thank you in advance
Most likely, you've opened it in a read-only mode. Try File -> Make Editable in your layout viewer.
Also check if all layers are selectable (press AS as highlighted) and that in objects palette all objects are selectable:
LaTeX Commands Quick-Menu:
