I'm working on a ultrasonic transmitter and receiver I need to use some sort of modulation and demodulation.
anyone has an idea where to start from, some datasheets for some ICs that I can learn about.
Amplitude modulation is probably the easiest option, although your carrier frequency is probably around 40 kHz. Your signal cannot be at a very high frequency. It needs to be slow enough so its waveshape is reproducable, as you trace from one peak to the next of the carrier waveform.
