Kishore Varsha
Hey Friends.....!!!!!!!!!!!! Can anyone help me to provide CCS C code for CC3200 works along with UltraSonic Sensor HC SR04...Please reply as soon.....i worked but it goes an irrelevant output please...
Note: This feature currently requires accessing the site using the built-in Safari browser.
// Application Name - Distance Measurement using Ultrasonic Sensor
// Standard includes
#include <string.h>
#include <stdlib.h>
// Driverlib includes
#include "hw_types.h"
#include "hw_ints.h"
#include "hw_memmap.h"
#include "hw_common_reg.h"
#include "hw_timer.h"
#include "interrupt.h"
#include "hw_apps_rcm.h"
#include "prcm.h"
#include "rom.h"
#include "rom_map.h"
#include "prcm.h"
#include "gpio.h"
#include "utils.h"
#include "timer.h"
#include "adc.h"
// Common interface includes
#include "gpio_if.h"
#include "pinmux.h"
#include "timer_if.h"
#include "uart_if.h"
// LOCAL DEFINES
#define APPLICATION_VERSION "1.0.0"
#define APP_NAME "UltraSonic Sensor"
#define adc = 8
#define FOREVER 1
int millisNow, millisPrev = 0;
int microsPrev = 0;
#define true 1
#define false 0
//important functioning defines
#define INTNUM 3 //interrupt pin 1 is digital pin 3 on the duemilanove
#define PULSE 10 //microseconds
#define CYCLETIME 50 //milliseconds - this is the time to wait until the sensor is asked to find
#define DISTCHANGE 2 to 15 // the distance again. #times/second = 1000/CYCLETIME = 20 in this case
#define DISTLOW 2
#define DISTHIGH 400
// GLOBAL VARIABLES -- Start
#if defined(ccs)
extern void (* const g_pfnVectors[])(void);
#endif
#if defined(ewarm)
extern uVectorEntry __vector_table;
#endif
unsigned int addr;
unsigned char pin;
unsigned int IntBase;
static volatile unsigned long g_ulBase;
char isHigh = false;
// GLOBAL VARIABLES -- End
// LOCAL FUNCTION PROTOTYPES
void LedWrite(unsigned int dtime);
void UltraSonic();
unsigned long micros()
return MAP_TimerValueGet(g_ulBase, TIMER_A);
unsigned long millis()
return MAP_TimerValueGet(g_ulBase, TIMER_A) * 1000;
MAP_IntDisable(IntBase); //lets not get interrupted while we are processing the first interrupt
int distance = dtime/58; //uS/58 = distance in cm => uS/148 = distance in inches
if (distance >= 2 || distance <= 400)
Report("Out of Range\r\n");
else
Report("Time :%d \nDistance = %d",dtime,distance);
Report(" cm\r\n");
MAP_UtilsDelay(8000);
void UltraSonic()
while(1)
GPIO_IF_LedOff(MCU_ALL_LED_IND);
// Base address for first timer
g_ulBase = TIMERA0_BASE;
Timer_IF_Init(PRCM_TIMERA0,g_ulBase,TIMER_CFG_PERIODIC,TIMER_A,0); // initiating timer
TimerLoadSet(g_ulBase, TIMER_A,1000);
TimerEnable(g_ulBase,TIMER_A);
/************************ MAKING ECHO PIN AS HARDWARE INTERRUPT **********************************/
GPIO_IF_GetPortNPin(7, &addr, &pin);//P62
MAP_GPIOIntTypeSet(addr,pin,GPIO_BOTH_EDGES);
if(addr==0x40004000){MAP_IntPrioritySet(INT_GPIOA0, INT_PRIORITY_LVL_1);IntBase=INT_GPIOA0;}
else if(addr==0x40005000){MAP_IntPrioritySet(INT_GPIOA1, INT_PRIORITY_LVL_1);IntBase=INT_GPIOA1;}
else if(addr==0x40006000){MAP_IntPrioritySet(INT_GPIOA2, INT_PRIORITY_LVL_1);IntBase=INT_GPIOA2;}
else if(addr==0x40007000){MAP_IntPrioritySet(INT_GPIOA3, INT_PRIORITY_LVL_1);IntBase=INT_GPIOA3;}
//Enable GPIO Interrupt
MAP_GPIOIntClear(addr,pin);
MAP_IntPendClear(IntBase);
MAP_IntEnable(IntBase);
MAP_GPIOIntEnable(addr,pin);
if(isHigh == false)
{ // pin LOW->HIGH
microsPrev = micros();
isHigh = true;
TimerDisable(g_ulBase,TIMER_A);
return;
else
{ //pin HIGH->lOW
LedWrite(micros());
isHigh = false;
microsPrev = 0;
return;
//! Main function
int
main()
// Configuring UART
InitTerm();
// Power on the corresponding GPIO port B for 9,10,11.
// Set up the GPIO lines to mode 0 (GPIO)
PinMuxConfig();
GPIO_IF_LedConfigure(LED1|LED2|LED3);
// Loop forever while the timers run.
while(FOREVER)
if( (millisNow = millis()) - millisPrev >= CYCLETIME)
{ //sufficient cycle time
GPIO_IF_GetPortNPin(9, &addr, &pin);//P64
GPIO_IF_Set(9, addr, pin, 1);
MAP_UtilsDelay(1000);
GPIO_IF_Set(9, addr, pin, 0);
millisPrev = millisNow; //reset clock
UltraSonic();
