neazoi
Advanced Member level 6
- Joined
- Jan 5, 2008
- Messages
- 4,157
- Helped
- 13
- Reputation
- 26
- Reaction score
- 15
- Trophy points
- 1,318
- Location
- Greece
- Activity points
- 37,198
Hello,
Recently I found this spectrum analyzer project https://www.astromag.co.uk/ssa/
It seems feasible and the resolution is quite high. The only great limitation I see is that the max span is 20KHz or up to 196KHz with very good sound blasters, so you have to advance the local oscillator frequency into 20KHz (or 196KHz) steps to cover larger bandwidths.
What is your oppinion about it?
Also I guess this setup suffers from the image signals, as these will appear at the mixer IF port, am I right?
Does it worth it, to try an I/Q mixer setup with a quadrature output DDS LO, combined with the I/Q receiver function of the spectrum lab software, in order to cancel out the image and lower the noise at the same time. I think this would make a much higher performance SA, what do you think?
