Astrid
Full Member level 3
- Joined
- Jul 11, 2011
- Messages
- 152
- Helped
- 4
- Reputation
- 8
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 2,492
I have a USB-powered electronics that has to work even after disconnecting from USB.
- Consumption is 100uA to 1 mA (for 100 ms) at 3V
- Used batteries are ultraminiaturní LiPo 40mAh, 1 cell 3.7V
Using switching converters for such a small current will probably ineffective, so I am thinking about using LDO.
the question is
- What LDO has its own consumption on the order of uA, preferably with automatic disconnection when the voltage drops below ~ 3V (battery protection).
The second question
How to make overlapping supply / switching power supply with power from USB?
Last question what use IC for charging such a small LiPo?
Iteální for me was a Aoonote with sample solution such things
the question is
The second question
