Note: This feature currently requires accessing the site using the built-in Safari browser.
As the outputs of ULN is "Low" you have to use Common anode displays. The connection for 4 displays is as given in the schematic. Cheersthelma said:pranam i'm very much clear that using uln2003 ,we can driver seven segment led's but wat if the display which am using is common anode??is it possible?? and can you tell me how to arrange 4 seven segment displays.
for example if am going to use 4 uln's and 4 sets of 7 seg led's, how can i interlink the design in order to make my process to work using my synchronous and asynchronous commands.
Sorry..i didnt get your question. Just read...So ans so's......Can you write it in detail?thelma said:fine pranam,am completely clear with ur ideas.
if i use so and so Ic, i can match with other so ans so IC. how should i start as a fresher??
