uC programmed but does not works
Shaheers
Islamabad,Pakistan
I am trying to implement a simple blinking circuit on bread board to checking purpose
I try for both atmel 89s52 and PIC18F452 for testing
I program 89s52 on Mickro C and Keil,
and PIC18F452 on Micro C and CSS C as well
I use old computer power supply to power them,
I am using Genius G540 to program them
both of circuits are works on proteus but not in real world,
is there any problem with crystal clock?
is there any problem in programming device, that device is using some sort of encruption while programming.
Is there any problem with power supply?
Is both of uC are faulty, even it programs and verify. . .. ?
the simple program in keil and sch are given
#include <REGX51.H>
#include <stdio.H>
#include <math.H>
void main()
	do{
		int i;
		for(i=0;i<10000;i++)
		P2= 0x80;
		P2= 0x00;
		}while (1);
For the 89S52:
Connect pin 40 (VCC) (Not shown in Proteus) to +5V.
Connect pin 20 (GND) (Not shown in Protues) to ground.
Connect pin 9 (RST) to ground via a 10k resistor. Connect a 10uF capacitor from +5V to pin 9 (RST).
Take a look here: **broken link removed**
Hope this helps.
Tahmid.
You need to reset circuit to operate.
Here is the basic circuit
Try this one
are you very sure of your programmer?
What is the frequency of the oscillator?
Your problem is that the delay you used is too small. While the LED does blink, the rate is too fast for our eyes to detect and it seems like the LED is on. Increase the delay time so that it's about 250ms or more.
You said that you tried using mikroC as well. Upload the mikroC code.
Also, upload the schematic and codes for the PIC.
What value of capacitors are you using for the crystal? Your schematic indicates 22nF, while a valid range is more in 20pF to 30pF range.
If the devices have been Code Protection enabled, you will need to manually erase the entire device before programming.
The power supply needs to be well regulated, proper use of bypass/decoupling capacitors is advisable.
Also some computer power supplies require a minimum load to function properly.
You might consider building a simply 7805 based power supply for your projects.
Highly Doubtful.
BigDog
Yeh is just got a new one, i think this is not a reasion.
The oscillator freq is 20Mhz.
The code i use in MikroC is for 80s52
void main ()
unsigned char j=1;
         for(;;)
         P0=j;                                            // same as for pic, with TRISA=0; and PORTA;
         P1=j;
         P2=j;
         P3=j;
         Delay_ms(1500);
         j=j<<1;
                if(j==0)
                j=1;
I think it is not a problem with code,
I am sorry i got a problem, the problem is probably capacitor, let me fix this first. . .
Is there any alternator of that crystal, any possibility to use micro-controller without crystal, like RC or internal oscillator?
ground the body of the crystal, make sure you make good use of power supply filter capacitors, increase the ground plane of you circuit so as to lower the inductance, measure the supply voltage across the power pin (GND and VDD) to be sure that it is within the set values, recompile and assemble your program once again....cheers
when digital systems tend to show bizarre attitudes one of the best bet will be to run a lower crystal value first then if all went well you can then push it to the limits of the chip and not starting it all up from the other side because things make get so bad...without you being able to combat it within a short while.
