Mansoor Ahmed
hello everybody,
i am using PIC24FJ128GA010. i am trying for UART with LCD display. Aim of my project is that i am just transmitting a character (for ex. "ABCD") but its not working for me, only the U2TX bit gets enable but in LCD nothing is getting displayed. i don't know what mistake i have done as i am new to this controller i am unable to rectify it. i have attached the code below kindly please verify and reply me.
thank you.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 #define FOSC 8000000 //device clock frequency (8MHz osc on Explorer16) #define FOSC/2 #include<p24FJ128GA010.h> #include "uart.h" //#define BAUDRATE 9600 #define EN PORTDbits.RD4 #define RS PORTBbits.RB15 #define DATA PORTE void delay(unsigned int a); void LCD_CMD(unsigned char); //Declaring LCD_CMD function void LCD_DATA(unsigned char*); //Declaring LCD_DATA function void __attribute__ ((interrupt, no_auto_psv)) _U2RXInterrupt(void) { LATA = U2RXREG; IFS1bits.U2RXIF = 0; } void __attribute__ ((interrupt, no_auto_psv)) _U2TXInterrupt(void) { IFS1bits.U2TXIF = 0; } void main() { unsigned char a[]="ABCD"; unsigned int i; // TRISF=0x0000; #if defined (__PIC24FJ256GB110__) || defined (__PIC24FJ256GA110__) // remap pins before intialising SPI2 // Unlock Registers __builtin_write_OSCCONL(OSCCON & 0xbf); // Configure Input Functions ********************** // Assign UART2RX To Pin RP10 RPINR19bits.U2RXR = 10; // Configure Output Functions ********************* // Assign UART2TX To Pin RP17 RPOR8bits.RP17R = U2TX_IO; // Lock Registers __builtin_write_OSCCONL(OSCCON | 0x40); #endif TRISA=0x0000; TRISD=0x0000; TRISE=0x0000; TRISB=0x0000; RCONbits.SWDTEN = 0; U2MODEbits.UARTEN = 0; // Bit15 TX, RX DISABLED, ENABLE at end of func U2MODEbits.USIDL = 0; // Bit13 Continue in Idle U2MODEbits.IREN = 0; // Bit12 No IR translation U2MODEbits.RTSMD = 0; // Bit11 Simplex Mode U2MODEbits.UEN = 0; // Bits8,9 TX,RX enabled, CTS,RTS not U2MODEbits.WAKE = 0; // Bit7 No Wake up (since we don't sleep here) U2MODEbits.LPBACK = 0; // Bit6 No Loop Back U2MODEbits.ABAUD = 0; // Bit5 No Autobaud (would require sending '55') U2MODEbits.RXINV = 0; // Bit4 IdleState = 1 U2MODEbits.BRGH = 0; // Bit3 16 clocks per bit period U2MODEbits.PDSEL = 0; // Bits1,2 8bit, No Parity U2MODEbits.STSEL = 0; // Bit0 One Stop Bit U2BRG = 9600; // baud rate // Load all values in for U1STA SFR U2STAbits.UTXISEL1 = 0; //Bit15 Int when Char is transferred (1/2 config!) U2STAbits.UTXINV = 0; //Bit14 N/A, IRDA config U2STAbits.UTXISEL0 = 0; //Bit13 Other half of Bit15 U2STAbits.UTXBRK = 0; //Bit11 Disabled U2STAbits.UTXEN = 0; //Bit10 TX pins controlled by periph U2STAbits.UTXBF = 0; //Bit9 *Read Only Bit* U2STAbits.TRMT = 0; //Bit8 *Read Only bit* U2STAbits.URXISEL = 0; //Bits6,7 Int. on character recieved U2STAbits.ADDEN = 0; //Bit5 Address Detect Disabled U2STAbits.RIDLE = 0; //Bit4 *Read Only Bit* U2STAbits.PERR = 0; //Bit3 *Read Only Bit* U2STAbits.FERR = 0; //Bit2 *Read Only Bit* U2STAbits.OERR = 0; //Bit1 *Read Only Bit* U2STAbits.URXDA = 0; //Bit0 *Read Only Bit* IFS1bits.U2TXIF = 0; // Clear the Transmit Interrupt Flag IEC1bits.U2TXIE = 1; // Enable Transmit Interrupts IFS1bits.U2RXIF = 0; // Clear the Recieve Interrupt Flag IEC1bits.U2RXIE = 1; // Enable Recieve Interrupts U2MODEbits.UARTEN = 1; // And turn the peripheral on U2STAbits.UTXEN = 1; LCD_CMD(0x01); //Set command to clear display screen delay(100); //Delay LCD_CMD(0x38); //Set command 2lines and 5x7 matrix delay(100); //Delay LCD_CMD(0x0F); //Set command to display ON cursor blinking delay(100); //Delay LCD_CMD(0x85); while(1) { for(i=0;i<4;i++) { U2TXREG= a[i]; LCD_DATA(a[i]); // delay(50); } } } void delay (unsigned int a) { unsigned int m,n; for(m=0;m<=a;m++) for(n=0;n<=125;n++); } void LCD_CMD(unsigned char ldata) //LCD_CMD function defination { DATA=ldata; //Sending the data to ldata RS=0; //RS=0 means it reading command EN=1; //Make EN high delay(10); //Delay EN=0; //Make EN low delay(10); //Delay } void LCD_DATA(unsigned char *ldata) //LCD_DATA function defination { while(*ldata!='\0') { RS=1; DATA=*ldata; //Sending the data to ldata //RS=1 means it reading data EN=1; //Make EN high delay(100); //Delay EN=0; //Make EN low delay(100); //Delay *ldata++; } }
thank you.
