Register Log in
UART Transmit issue with CPLD
reservevoltage
Hello,
I have a demo card named cpld c-m240 epm240t100c5n.
I tried to send the data with uart and have a synchronous problem. (ı think)
According to my basic information in Uart communication, the duration of 1 or 0 for each bit (at 9600 baudrat and 50Mhz clok) is 104us.
I divided the 50Mhz to 9600 and created a counter according to the result.
Unfortunately ı could not figure out test bench logic. That is why the code is running without a simulation.
I had realized differences between sended byte and described byte at code when ı read the sended value from realterm.
My code is below. Does anyone hava a suggestion?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity main is
    Generic (
        CLK_FREKANS : integer := 50000000;
        BAUDRATE : integer 	:= 9600
    Port(
		in_clk : in std_logic;
        in_rst : in std_logic;
        in_tx_start : in std_logic;
        in_tx_data : in std_logic_vector(7 downto 0):="10101010";--sended data
        out_tx : out std_logic;
        out_tx_ok : out std_logic
end main;
architecture Behavioral of main is
    constant CLK_BIT : integer := (CLK_FREKANS / BAUDRATE);--5208
    type t_UART_tx is (IDLE, START_B, SEND_D, STOP_D, Transmit_OK);
    signal r_UART_tx : t_UART_tx := IDLE;
    signal r_clk_counter : integer range 0 to CLK_BIT-1 := 0; -- 0 to 5207
    signal r_data_ind : integer range 0 to 7 := 0;
    signal r_data   : std_logic_vector(7 downto 0) := (others => '0');
    signal r_tx : std_logic := '1';
    signal r_tx_ok : std_logic := '0';
	 signal counter: integer range 0 to 96000:=0;
begin
    out_tx <= r_tx;
    out_tx_ok <= r_tx_ok;
process(in_clk, in_rst)
    begin
        if in_rst = '1' then
            r_UART_tx <= IDLE;
            r_clk_counter <= 0;
            r_data_ind <= 0;
            r_data <= (others => '0');
            r_tx <= '1';
            r_tx_ok <= '0';
        elsif rising_edge(in_clk) then
            r_tx_ok <= '0';
            case r_UART_tx is
                when IDLE =>
							--r_tx <= '1';
							r_clk_counter <= 0;
							r_data_ind <= 0;
						   if in_tx_start = '1' then
								r_data <= in_tx_data;
								r_UART_tx <= START_B;
							end if;
                when START_B =>
                     if r_clk_counter = CLK_BIT then --=5207
                        r_clk_counter <= 0;
								r_tx <= '0';
                        r_UART_tx <= SEND_D;
                     else
						       r_clk_counter <= r_clk_counter + 1;
                     end if;
					 when SEND_D =>
								r_clk_counter <= 0;
								r_tx  <= r_data(r_data_ind);
                        if r_data_ind = 7 then
							    r_data_ind <= 0;
                                r_UART_tx <= STOP_D;
                        else
									r_data_ind <= r_data_ind + 1;
                        end if;
							else
							end if;
 					 when STOP_D =>
                      if r_clk_counter = CLK_BIT then --=5207--=5207
                         r_clk_counter <= 0;
								 r_tx  <= '1';
                         --r_UART_tx <= Transmit_OK;
								 if counter=96000 then
								 else
								    counter<=counter+1;
								 end if;
                      else
                      end if;
					  when Transmit_OK =>
				          r_tx  <= '1';
                      r_tx_ok <= '1';
                      r_UART_tx <= IDLE;
					  when others => NULL;
				end case;
			end if;
end process;
end Behavioral;
FvM
Super Moderator
Staff member
Bochum, Germany
A first sight, you are defining
but comparing
which never occurs.
There may be more errors.
Also wrong sequence. Output is set to '0' after start bit but should be set to data LSB.
What do you mean with "could not figure out test bench logic"? Don't understand VHDL? Test bench for TX is really simple, just generate clock, reset and start, then watch internal states and output in wave viewer.
reservevoltage
Hi FvM,
ı have changed some line at my code and wrote test bench code.
However still ı can not communicate with PC by using usb TTL. I have no ıdea what ı have to do.
Could you examine the code and please tell me where is my mistake
test code
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_signed.all;
use ieee.std_logic_arith.all;
entity test is
end test;
architecture modul of test is
--COMPONENT definition
component TX_MODUL
port
	  (clk: 		in std_logic;
		reset:  	in std_logic;
		data: 		in std_logic_vector( 7 downto 0);
		flag: 		out std_logic;
		transmit:	out std_logic);
end component TX_MODUL;
--SIGNAL definition
signal clk		: std_logic:='0';
signal reset		: std_logic:='0';
signal data		: std_logic_vector( 7 downto 0):= (others => '0');
signal flag		: std_logic:='0';
signal transmit	: std_logic:='1';
--time definition
signal board_osc_period : time := 20 ns;
begin
--COMPONENT equalization
C1: TX_MODUL   port map (
					clk		=> clk,
					reset		=> reset,
			   	data		=> data,
					flag		=> flag,
					transmit	=> transmit
zamanlama: process
			  begin
			  clk<='0';
			  wait for board_osc_period/2;
			  clk<='1';
			  end process;
transmint: process
			  begin
			  wait for 10 us;
			  flag<='0';
			  data<="11110000";
			  wait for 1 us;
			  flag<='1';
			  wait for 1 us;
			  end process;
end modul;
TX code
library ieee;
entity TX_MODUL is
port
		clk: 			in std_logic;
end TX_MODUL;
architecture modul of TX_MODUL is
signal idle_counter: integer range 0 to 52085:=0;
signal counter: integer range 0 to 5209:=0;
signal index  : integer range 0 to 7:=0;
signal b_data : std_logic_vector( 7 downto 0):="00000000";
signal b_transmit: std_logic:='1';
signal b_flag: std_logic:='0';
type state_m is(IDLE, START, SEND, STOP);
signal state_new: state_m :=IDLE;
begin
transmit <= b_transmit;
flag	 <= b_flag;
process(clk,reset)
	begin
		if (reset='1') then
			counter<=0;
			index<=0;
			b_transmit<='1';
			b_flag<='0';
			b_data<="00000000";
			state_new<=IDLE;
		elsif rising_edge(clk) then
			case state_new is
				when IDLE=>
					if counter=5208 then    --added
						index<=0;
						counter<=0;
						b_transmit<='1';
						if (b_flag='0') then
							b_data<=data;
							b_flag<='1';
							state_new<=START;
						end if;
					else counter<=counter+1;
					end if;--eklendi
				when START=>
				b_transmit<='0';                  --changed line
						counter<=0;
						state_new<=SEND;
					else counter<= counter+1;
					end if;
				when SEND=>
				b_transmit<=b_data(index);        --changed line
						if index=7 then
						   index<=0;
						   state_new<=STOP;
						else index<= index+1;
						end if;
						counter<=0;
					end if;
				when STOP=>
						b_transmit<='1';
						counter<=0;
						b_flag<='0';
						state_new<=IDLE;
					end if;
			end case;
		end if;
end process;
end modul;
Code was previous version. Accidentally posted.
New version is a below.
Transmit
library ieee;
entity tx is
port
		clk: 		in std_logic;
end tx;
architecture modul of tx is
type state_m is(IDLE, START, D0,D1,D2,D3,D4,D5,D6,D7, STOP1,STOP2,SecureDelay);
begin
flag	 <= b_flag;
process(clk,reset)
	begin
		if (reset='1') then
			counter<=0;
			index<=0;
			b_transmit<='1';
			b_flag<='0';
			b_data<="00000000";
			state_new<=IDLE;
			case state_new is
				when IDLE=>
				b_transmit<='1';
				index<=0;
				counter<=0;
				if(b_flag<='0') then
				   b_data<=data;
				   b_flag<='1';
				   state_new<=START;
				end if;
				when START=>
				b_transmit<='0';
				   counter<=0;
				   state_new<=D0;
				end if;
				when D0=>
				b_transmit<=b_data(0);
				   counter<=0;
				   state_new<=D1;
				end if;
				when D1=>
				b_transmit<=b_data(1);
				   counter<=0;
				   state_new<=D2;
				end if;
				when D2=>
				b_transmit<=b_data(2);
				   counter<=0;
				   state_new<=D3;
				end if;
				when D3=>
				b_transmit<=b_data(3);
				   counter<=0;
				   state_new<=D4;
				end if;
				when D4=>
				b_transmit<=b_data(4);
				   counter<=0;
				   state_new<=D5;
				end if;
				when D5=>
				b_transmit<=b_data(5);
				   counter<=0;
				   state_new<=D6;
				end if;
				when D6=>
				b_transmit<=b_data(6);
				   counter<=0;
				   state_new<=D7;
				end if;
				when D7=>
				b_transmit<=b_data(7);
				   counter<=0;
				   state_new<=STOP1;
				end if;
				when STOP1=>
				b_transmit<='1';
				   counter<=0;
				   state_new<=STOP2;
				end if;
				when STOP2=>
				 b_transmit<='1';
				if counter=2604 then
				   counter<=0;
				   state_new<=SecureDelay;
				end if;
				When SecureDelay=>
				b_transmit<='1';
				   counter<=0;
				   b_flag<='0';
				   state_new<=IDLE;
				end if;
			end case;
		end if;
    end process;
end modul;
Test
library ieee;
entity test is
end test;
component tx
port
	  (clk: 			in std_logic;
end component tx;
--SIGNAL definition
--time definition
begin
C1: tx   port map (
					clk		=> clk,
					reset		=> reset,
			   	data		=> data,
					flag		=> flag,
zamanlama: process
			  begin
			  clk<='0';
			  clk<='1';
			  end process;
transmint: process
			  begin
			  wait for 100 us;
			  flag<='0';
			  data<="11001100";
			  wait for 1040 us;
			  flag<='1';
			  wait for 100 us;
			  end process;
end modul;
ads-ee
Super Moderator
Staff member
USA
Run the code and the testbench in a simulator and observe in the waveform view what the design is doing and debug why it isn't doing what it was supposed to do. As you already have a testbench run it in the simulator and display the waveform starting with the data you are inputting and look at how it gets serialized and sent.
If the design works in simulation and not on hardware then look carefully at the timing constraints and make sure you don't have any unconstrained paths.
That is your job. You will learn more if you make the effort to learn how to debug the code you've written in a simulator.
Toggle Sidebar
Design Fast
