Anuradha1
Member level 2
Hello all,
I am using PIC simulator IDE to simulate my assembly code written for pic16f877a with oscillator frequency 16MHz.
I am sending data to UART.
In my code i can adjust the delay between sequent transmission as follows.
movf WH,0
movwf TXREG ;Transmit to PC
call Delay
call Delay
movf WL,0
call Delay
call Delay
The Delay loop I have written is given below.
Delay
decfsz CounterL,1
goto Delay
return
But when i simulate it doesnot transmit data to UART simulation interface according to the delay time i have given in the program.
I can increase the transmission rate by reducing tx delay time in "Change UART Transmit/Receive time" in option tab of the IDE window. When i reduce this time the simulator works nicely according to the time set there.
What i want to know is Can i adjust the delay of sequent transmissions in my code, so that it works according to the delay i need/ i give, not depending on the value set at "Change UART Transmit/Receive time" of simulator interface.
As i have seen simulator doesnot take the delays given in the code.
Also what is the minimum time duration I can have between two sequent transmissions from Uart?
Any information? advice regarding this matter is appreciated.
Thanks in advance.
movf WH,0
call Delay
call Delay
movf WL,0
call Delay
call Delay
Delay
decfsz CounterL,1
goto Delay
return
Thanks in advance.
