[PIC] UART RX Interrupt for PIC 18
qne
hello...
friends i am trying to do a task through serial interrupt..
problem is that intrrupt happend only once. code dsoent return from ISR to recieve new interrupt...
help...
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
// pic 18F452
// MiKroC for PIC
void main()
 TRISC.f6 = 0;
 TRISC.f7 = 1;
 SPBRG = 15;                       //9600 BR with 10MHz
RCSTA.SPEN=1;                                // activate Rx pin)
TXSTA.TXEN=1;                                // Activate Tx pin Transmissiom
RCSTA.CREN=1;                                // Activate Reception
PIE1.RCIE=1;                                // Enable Reception interrupt
INTCON.GIE=1;                                // Enable Global interrupt
INTCON.PEIE=1;                                // Enable Peripheral interrup
while(1); // waiting for interrupt
// ISR upon serial RX interrupt
void Interrupt()
PORTD = 0XAA;
delay_ms(100);
PORTD = 0XFF;
PIR1.RCIF = 0;
Your code is almost correct but it will only receive one character per 100mS, if you are sending at 9600 bauds you would expect to receive 960 characters per second (10 bits per character).
Remove the delay from the interrupt routine, in general you should never do anything to slow down an interrupt because while sitting in the delay routine, other interrupts could be missed. If you want PORTD to change to show when a character has been received, use the interrupt routine to set a variable and check it and reset it in the while() loop. You probably also want to read the RCREG inside the interrupt routine, even if you don't use the value elsewhere.
Brian.
